Aller au contenu principal
The Casio fx-9750GII is a graphing calculator sold by Casio. Identified the title "fx-9750GII" in the top right-hand corner of the calculator's front face.
Why are my function keys not working properly?
My function keys are not working properly.
In Run-Math program, if I press F1, nothing happens. If I press F2, it opens a list of options in the botton (LIST, MAT, CPLX, CALC, STAT). If I press F3 it opens another list of options (V-WIN, FACT, STAT, GRPH, DYNA). If I press F4, it acts as going into the previous screen (For example, If I am in Run-math and I was in the menu before, it goes to the menu and if I press it again it goes back to the Run-math). F5 acts as the Left arrow key in text editors. F6 acts as moving back a line (selecting the previous line).
Every other button work as intended.
I tried to reset the system through the menu, but since the function keys aren’t working properly, I can’t select the reset option. I’ve also tried the small button on the back of the calculator, but it doesn’t do much.
Répondre à cette question J'ai le même problème
Indice 1
Ajouter un commentaire
2 Réponses
Hello Ricardo, did you maybe had a spill onto the keyboard?, also if the unit is old, ( i don’t know how old) some buttons might stop working , like buttons of tv remotes, it might be worth it to open the whole thing to have a look if its dirty or worn out . if its worn out, there is a conductive glue available from specialised electronic shops, just cover the tip of the missing carbon rubber with a very thin layer of the conductive glue , wait for it to dry, reassemble. also while you have it open, maybe then you can check if bridging corresponding pad of the reset option would do anything. good luck.
Indice 0
Try to redownload the program. I had the same issues and it helped me. It gave me a lot of problems because I used it for education. Fortunately, this site https://plainmath.net/textbooks/ saves me from failing lessons. But maybe someone has other more smart suggestions?
Indice 0
Ajouter une réponse
Ricardo OKay sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 11
Total : 986
