Aller au contenu principal
Voici comment réparer votre iPhone 14 Pro. Sorti le 16 septembre, le "plus petit" smartphone phare d'Apple est doté d'un écran OLED ProMotion de 6,1 pouces, d'une caméra arrière à triple objectif, de la 5G et de l'encoche interactive Dynamic Island autour de la caméra frontale et des capteurs supérieurs. Successeur de l'iPhone 13 Pro.
20 questions Voir tout
In back side one white spot
I’m recently buy this phone dark purple I phone 14pro but there is one white spot on back side. I’m asking to shoe they said to contact in IFIX. I’m buy 3 phone at time but 2 phone is colour but mine defective. Apple giving this type service to the customer I’m not happy with this.
Répondre à cette question J'ai le même problème
Indice 1
Ajouter un commentaire
1 Réponse
Réponse la plus utile
Hi Mahendra,
If I'm reading your question correctly, you just bought a new iPhone 14 Pro and there's a defect in the color on the back glass, is that right?
At this point you have three options.
  1. Return the phone for a replacement. Given that this is the latest model and should still be under warranty, you should be able to get it replaced.
  2. Replace the back glass. This is an extremely difficult repair, as the adhesive used on the rear glass of most iPhones is extremely strong, so it requires a heat gun or laser to loosen the glue enough to be able to chip the glass out of the frame.
  3. Replace the entire rear chassis. This saves you the difficulty of removing the rear glass, but that gets made up for by the fact that you have to transfer every single component inside the phone to the new housing.
Unfortunately, your phone is so new that no guides are available for replacing the rear glass or the chassis; you may be able to find YouTube videos, but none of the regular repair sites I'm aware of has any information on the 14 Pro.
I'd strongly suggest contacting either the seller or Apple itself to see about a warranty replacement.
Indice 1
Ajouter une réponse
Mahendra Kumavat sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 1,353
