Aller au contenu principal
Locating Backlight fuse, display backlight not working anymore
Hello,
I damaged the display on my T14s Gen 3 AMD and purchased a replacement panel that appears to be fully compatible (matching FRU and model). After connecting the 30-pin cable, the display works, but unfortunately, there’s no backlight on the display.
I suspect the issue might be related to the backlight fuse, but I’m unsure of its location. Do you have any suggestions or guidance on where I can find it?
Thank you in advance!
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
1 commentaire
we need to know if your motherboard is a LCFC NM-F151 or a LCFC NM-E422 or some other board
par
Ajouter un commentaire
2 Réponses
Solution retenue
Resolved! the backlight fuse named FV1 3a 32v is here
I replaced it and everything works again.
Indice 0
1 commentaire:
I killed my backlight by misaligning the connector whilst having the system powered on. Pretty sure the fuse was blown after seeing electrical sparks.
@greyxor45664 What model of the fuse should I buy? and do you have the boardview+schematics for it?
par
@greyxor45664 Explain this "I accidentally damaged the screen" a bit more. After all, if you think it is the backlight fuse we need to know how it may have gotten shorted out. The other thing that will help if you post some really good, large pictures with your Question. That way we can try and help you to identify the "fuse". Remember, there is more than the fuse that makes up the backlight. Yes, the fuse is a good start, but do not forget the display connector. I have seen more damage on those then an actual blown fuse. It is also possible that this is a backlight driver error. Just making sure you are not too focused on just one thing.
Ajout d'images à une question existante
Indice 0
1 commentaire:
It was indeed the backlight fuse.
Thanks for your help
par
Ajouter une réponse
GreyXor sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 37
30 derniers jours : 100
Total : 1,121
