Aller au contenu principal
Is it possible to replace the hard disk with an SSD?
I would like to clone the current HDD with an SSD to make it faster.
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
Ajouter un commentaire
1 Réponse
Solution retenue
@piero90 yes, you can. Now, with that said, it will depend on what motherboard/processor you have. If your motherboard does not have an M2 slot, you will need to get a 2.5" SATA3 SSD. Something like a Kingston’s KC600 would work
If it does have an M2 use the appropriate SSD for that.
"Support for 6.35-cm (2.5-in) SATA hard drives in 7.0-mm (.28-in) and 9.5-mm (.37-in) thickness Support for M.2 SATA storage (Port 0) (models with i7 processors and 4 GB discrete graphics memory only)" from the HP Envy Maintenance And Service Guide. Page 55 shows you how to check it out and to work on it.
Indice 2
7 commentaires:
Is the following docking station good for cloning laptop HDD to SSD?
https://www.amazon.it/Inateck-Dual-Bay-f...
par
@piero90 I have not use that particular one but use a similar setup daily without any issues.
par
@oldturkey03 Good evening, this SSD is good for notebook?
https://www.amazon.it/Samsung-Memorie-MZ...
par
@piero90 Looks like it should work, 2TB :-) Awesome!
par
Voir 2 commentaires en plus
Ajouter une réponse
Piero Sabino sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 14
Total : 84
