Aller au contenu principal
Pour réparer ensemble - Je crée un compte
laptop won't power on after replacing the battery
I recently received a battery from ifixit, to replace the one that went out, so I thought. I replace it with the new battery and it won't power on. The fans kick in for a bit but that's pretty much it. Any suggestions?
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
2 commentaires
Hi @annettebarnhart
Without turning the laptop on, does the laptop indicate that the battery is charging when the charger is connected?
If so, have you fully charged the battery?
par
Hi, the battery indicates that its fully charged and it was fully charged.
par
Ajouter un commentaire
3 Réponses
Solution retenue
Hi @annettebarnhart
Try a full power refresh and check if that resolves the problem, in case a corrupted BIOS is causing the problem.
Disconnect the charger if connected and then open the laptop and remove the main battery from the motherboard.
Unplug the RTC coin cell battery from the motherboard. Unfortunately for you it is located on the underside of the motherboard
Here's the service manual that will help. Go to p.33 to view the procedure to remove the coin cell battery.
Once the coin cell battery is removed, measure its voltage. If it is <2.5.V DC or if it is >4-5 years old, replace it. Search online for W6NPD to find suppliers that suit you best.
Reconnect the coin cell battery (or its replacement) and reassemble the motherboard etc into the laptop.
Reconnect the main battery and close the laptop.
Connect the charger and check if it turns on OK.
If it does there may be a message stating that the date and time are incorrect. This is normal as the BIOS has been reset back to its factory default state. Once the date and time have been corrected, the message won't appear again. Also if any user definable BIOS settings have been changed by you, to suit whatever system requirements you have, they will need to be changed back also.
Indice 2
Bad battery incompatible
Indice 0
It's very frustrating when a simple part swap leads to a bigger problem. The fact that your Dell Precision 5530's fans kick on briefly but it won't power on is a classic symptom of what's called a "no POST" (Power-On Self-Test) situation. The laptop is receiving power and attempting to start, but something is failing the initial checks.
Since this happened immediately after you replaced the battery, the problem is almost certainly related to that process. Here are the most likely causes and a step-by-step troubleshooting guide.
The Most Likely Causes
  1. Improper Connection: The new battery might not be seated correctly, or the battery connector might be misaligned. This is the simplest and most common cause.
  2. Damaged Internal Components: While working inside the laptop, it's possible for a delicate cable or component to be accidentally dislodged or damaged. A common mistake is not fully disconnecting the AC power and the old battery before working on the system, which can cause a short circuit.
  3. Faulty New Battery: Although less likely from a reputable supplier like iFixit, there's always a chance the new battery is defective.
  4. Static Electricity Damage: Without taking proper anti-static precautions (like an anti-static wrist strap), a static discharge could have damaged a sensitive component on the motherboard.
Step-by-Step Troubleshooting
Here's what you should do, starting with the simplest and safest fixes.
Step 1: Perform a Hard Reset (Power Drain)
This is the most crucial first step after any internal component work. It clears any residual power from the motherboard and can often resolve a no-POST issue.
  1. Disconnect the AC Adapter: Make sure the laptop is completely unplugged from its charger.
  2. Disconnect the Battery: Carefully open the laptop and disconnect the new battery from the motherboard.
  3. Hold the Power Button: Press and hold the power button for 15-20 seconds to drain all residual "flea" power from the system.
  4. Reconnect the AC Adapter (Only): Plug the AC adapter back in, but leave the new battery disconnected.
  5. Power On: Try to power on the laptop. If it turns on, you know the motherboard and AC power supply are working. This would point to the new battery or its connection as the problem.
  6. Reconnect the Battery: If the laptop powered on with just the AC adapter, shut it down, reconnect the new battery, and try to power it on with both the AC adapter and the battery.
Step 2: Check the Battery Connection
  • Reseat the Battery: Power down the laptop, disconnect the AC adapter, and disconnect the battery. Carefully inspect the connector on both the motherboard and the battery. Make sure no pins are bent and that the connection is clean. Reconnect the battery, ensuring it snaps or locks into place securely.
Step 3: Check for Diagnostic LED Patterns
Dell laptops often use a sequence of blinking lights to indicate a specific error.
  • When you press the power button, look closely at the power button LED and the LED on the front edge of the laptop (the battery status indicator).
  • Does it flash a specific pattern of amber and white lights? For example, a 2-3 pattern might indicate a memory issue, while a 2-8 pattern might indicate a display issue.
  • Check the Dell Support website for the Diagnostic and Battery Indicators manual for your Precision 5530 to decode the specific light pattern. This can tell you exactly what's failing the POST.
Step 4: Check Other Internal Connections
  • Since you were already inside the machine, it's worth double-checking other easily-disturbed components.
  • Reseat the RAM: The memory modules are located close to the battery on some laptops. Carefully remove and re-insert them, making sure they are firmly seated.
  • Check Ribbon Cables: Inspect any other ribbon cables you might have had to move (like the trackpad or keyboard cables) to ensure they are properly seated in their connectors.
Step 5: Test the Old Battery
  • If none of the above steps work, try putting the old battery back in (if it's not physically swollen or damaged).
  • Even if the old battery was dead, it should at least allow the laptop to power on with the AC adapter connected. If the laptop powers on with the old battery but not the new one, you've isolated the problem to the new battery itself.
If you've performed all these steps and the laptop still won't power on, the issue is likely more serious and may require professional repair. It's possible that the initial power-off was caused by an underlying motherboard issue, and the battery replacement process was just a coincidence that triggered the failure.
Indice 0
Ajouter une réponse
Annette Barnhart sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 32
30 derniers jours : 137
Total : 1,525
