Aller au contenu principal
2012 Chevy Equinox Tail Light Bulb Replacement
Kelly Dixon
Kelly Dixon et un autre contributeur
Dernière mise à jour le December 21, 2020
20 minutes
Facile
If the tail light bulb on the back of your 2012 Chevy Equinox has gone out, you know it is time to replace it. Use this guide to replace the tail light bulb on your vehicle.
Driving with a tail light bulb out in your car can be dangerous and is illegal in some places. Getting pulled over or getting in an accident from this can be expensive and time consuming. Replacing a tail light bulb that has gone out is an easy fix that can help save time, money, and keep you and your family and friends safe.
Before beginning the process of replacing your tail light, inspect your vehicle to find out which light bulb has gone out. It may be time to replace multiple bulbs because many light bulbs last for around the same time.
Make sure to turn your vehicle off before you start disassembly.
Ce dont vous avez besoin
iFixit touche une commission lorsque vous achetez par l'intermédiaire de ces liens.
  1. 2012 Chevy Equinox Tail Light Bulb Replacement, Tail Light Bulb: étape 1, image 1 de 3 2012 Chevy Equinox Tail Light Bulb Replacement, Tail Light Bulb: étape 1, image 2 de 3 2012 Chevy Equinox Tail Light Bulb Replacement, Tail Light Bulb: étape 1, image 3 de 3
    • Open the trunk of your car.
  2. 2012 Chevy Equinox Tail Light Bulb Replacement: étape 2, image 1 de 3 2012 Chevy Equinox Tail Light Bulb Replacement: étape 2, image 2 de 3 2012 Chevy Equinox Tail Light Bulb Replacement: étape 2, image 3 de 3
    • Remove the two plastic caps by placing a spudger in the bottom opening and gently prying upward.
  3. 2012 Chevy Equinox Tail Light Bulb Replacement: étape 3, image 1 de 3 2012 Chevy Equinox Tail Light Bulb Replacement: étape 3, image 2 de 3 2012 Chevy Equinox Tail Light Bulb Replacement: étape 3, image 3 de 3
    • Remove the two 6 mm Phillips #2 screws located underneath each of the plastic caps by twisting counterclockwise.
  4. 2012 Chevy Equinox Tail Light Bulb Replacement: étape 4, image 1 de 3 2012 Chevy Equinox Tail Light Bulb Replacement: étape 4, image 2 de 3 2012 Chevy Equinox Tail Light Bulb Replacement: étape 4, image 3 de 3
    • Hold the latch down firmly and pull the tail light cover off the vehicle.
    • You may have to apply a back and forth force to remove the cover.
  5. 2012 Chevy Equinox Tail Light Bulb Replacement: étape 5, image 1 de 3 2012 Chevy Equinox Tail Light Bulb Replacement: étape 5, image 2 de 3 2012 Chevy Equinox Tail Light Bulb Replacement: étape 5, image 3 de 3
    • Remove the light bulb socket from the vehicle by gently twisting and pulling it out of the tail light cover.
  6. 2012 Chevy Equinox Tail Light Bulb Replacement: étape 6, image 1 de 3 2012 Chevy Equinox Tail Light Bulb Replacement: étape 6, image 2 de 3 2012 Chevy Equinox Tail Light Bulb Replacement: étape 6, image 3 de 3
    • Twist the light bulb counterclockwise and pull to remove it from the socket.
  7. 2012 Chevy Equinox Tail Light Bulb Replacement: étape 7, image 1 de 3 2012 Chevy Equinox Tail Light Bulb Replacement: étape 7, image 2 de 3 2012 Chevy Equinox Tail Light Bulb Replacement: étape 7, image 3 de 3
    • Insert the new light bulb by gently pushing the light bulb into the socket and twisting clockwise.
    • When reassembling, make sure to align the tail light cover up to the back of the vehicle before pushing the cover back on.
Kelly Dixon
Membre depuis le 10/13/20
145 Réputation
1 tutoriel rédigé
Équipe
Texas Tech, Team S9-G2, Cowan Fall 2020 Membre de l'équipe Texas Tech, Team S9-G2, Cowan Fall 2020
TTU-COWAN-F20S9G2
1 membre
1 tutoriel rédigé
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 39
Total : 2,276
