Aller au contenu principal
ASUS  X540BA-BB61-CB Screen Replacement
David Shodipo
David Shodipo et 3 autres contributeurs
Dernière mise à jour le January 16, 2025
20 - 40 minutes
Modérée
Photos d’action
A besoin de meilleures images
Nécessite plus d'images
Use this guide to replace a cracked or malfunctioning display screen of your ASUS laptop. This guide is for model: X540BA-BB61-CB
This guide will have you work with sensitive electronics, so before you start, make sure you have an Electrostatic Discharge wrist strap, as this prevents electronic damage. If you don't have one, you can order one from the parts list in this guide!
Ce dont vous avez besoin
Outils
Afficher plus…
  1. ASUS  X540BA-BB61-CB Screen Replacement, Power Down the Laptop: étape 1, image 1 de 2 ASUS  X540BA-BB61-CB Screen Replacement, Power Down the Laptop: étape 1, image 2 de 2
    • Power off the device and unplug it from the charging cord.
  2. ASUS  X540BA-BB61-CB Screen Replacement, Remove the Bezel Frame: étape 2, image 1 de 2 ASUS  X540BA-BB61-CB Screen Replacement, Remove the Bezel Frame: étape 2, image 2 de 2
    • Use a spudger to remove the plastic screw covers in the bottom right and left corner of the screen.
    • Remove the two Phillips #2 (M2.5 x4)mm flat head screws in the two bottom corners under the screw covers.
    • Then remove the bezel frame with a spudger.
  3. ASUS  X540BA-BB61-CB Screen Replacement, Remove the Bezel: étape 3, image 1 de 1
    • Once these screws are removed, carefully remove the bezel by the inner edge working your way around the perimeter.
    • Be careful to undo the clips as you remove the bezel and don't yank it off. The bezel is flexible but can break.
  4. ASUS  X540BA-BB61-CB Screen Replacement, Remove the grounding tape: étape 4, image 1 de 1
    • Remove the grounding tape covering the screws in the four corners of the screen.
    • Use a Phillips #2 screwdriver to remove four (M2 x 4) mm screws from the four corners of the screen that hold the LCD panel in place.
  5. ASUS  X540BA-BB61-CB Screen Replacement, Remove the Screen: étape 5, image 1 de 1
    • Peel off one side of the tape and remove the two bottom screws.
    • It is important to remember that the video cable is secured with cleared tape.
    • Peel off the tape, gently slide the cable out and remove the LCD Panel. Take the new LCD panel and place it on the keyboard.
    • Gently slide the connector to the jack secured with cleared tape with both hands.
David Shodipo
Membre depuis le 01/14/22
1 Réputation
1 tutoriel rédigé
Équipe
York University, Team R-31, Melo-Thaiss Winter 2022 Membre de l'équipe York University, Team R-31, Melo-Thaiss Winter 2022
YORK-MELO-THAISS-W22SRG31
1 membre
1 tutoriel rédigé
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 19
30 derniers jours : 141
Total : 1,808
