Aller au contenu principal
ASUS Chromebook C424MA-DH48F Speakers Replacement
Anthony Wink
Anthony Wink et un autre contributeur
Dernière mise à jour le December 19, 2024
5 minutes
Très facile
This is the ASUS Chromebook (Model C424MA-DH48F), here we will be guiding you though replacing the speakers for the ASUS Chromebook.
Reasons to replace the speakers include:
  • Physical damage
  • Poor sound quality
  • No sound at all
  • Sound distortion
Ce dont vous avez besoin
Outils
Afficher plus…
  1. ASUS Chromebook C424MA-DH48F Speakers Replacement, Lower Case: étape 1, image 1 de 2 ASUS Chromebook C424MA-DH48F Speakers Replacement, Lower Case: étape 1, image 2 de 2
    • Use a Phillips #0 screwdriver to remove the eleven 6.9 mm screws that secure the lower case.
    • Make sure all the screws on this side get taken out because there could be a label or warranty sticker covering up a screw that might be missed.
    • Insert an opening pick into the gap between the lower case and chassis.
    • Slide the pick around the entire perimeter of the laptop until the lower case fully releases.
    • Remove the lower case.
  2. ASUS Chromebook C424MA-DH48F Speakers Replacement, ASUS Chromebook C424MA-DH48F Battery Disconnection: étape 2, image 1 de 3 ASUS Chromebook C424MA-DH48F Speakers Replacement, ASUS Chromebook C424MA-DH48F Battery Disconnection: étape 2, image 2 de 3 ASUS Chromebook C424MA-DH48F Speakers Replacement, ASUS Chromebook C424MA-DH48F Battery Disconnection: étape 2, image 3 de 3
    • Use an opening tool to pop up the silver locking bar securing the battery connector.
    • Push the battery connector directly out of its motherboard port.
  3. ASUS Chromebook C424MA-DH48F Speakers Replacement, Speakers: étape 3, image 1 de 3 ASUS Chromebook C424MA-DH48F Speakers Replacement, Speakers: étape 3, image 2 de 3 ASUS Chromebook C424MA-DH48F Speakers Replacement, Speakers: étape 3, image 3 de 3
    • Use an opening tool or your fingernails to gently "walk" the speaker connector directly out of its motherboard socket.
  4. ASUS Chromebook C424MA-DH48F Speakers Replacement: étape 4, image 1 de 1
    • Lift the right speaker up and out of the chassis, with care not to strain the connected cable.
  5. ASUS Chromebook C424MA-DH48F Speakers Replacement: étape 5, image 1 de 1
    • Unseat the speaker wires from the lower side of the battery.
  6. ASUS Chromebook C424MA-DH48F Speakers Replacement: étape 6, image 1 de 1
    • Lift the left speaker up and out of the chassis.
Anthony Wink
Membre depuis le 08/28/24
401 Réputation
3 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 6
Total : 21
