Aller au contenu principal
Acer Aspire 5100 Fan Replacement
Brad Rollinson
Brad Rollinson et 13 autres contributeurs
Dernière mise à jour le November 7, 2022
10 minutes
Modérée
Over time, your Acer Aspire 5100 laptop’s fan may stop working. Laptops without working fans may overheat, damaging internal hardware such as the CPU, hard drive, and motherboard. You may have a broken fan if your laptop regularly feels hot or crashes, your fan makes abnormal or no noise, or your vents lack airflow. If these problems occur, you will need a replacement fan to keep your laptop regulated and running smoothly.
This guide will help you replace your broken fan in four simple steps. Before starting, be sure to unplug your laptop and remove the battery for your personal safety.
Ce dont vous avez besoin
Pièces
Outils
  • Phillips #0 Screwdriver
  • Spudger
    Spudger
Afficher plus…
iFixit touche une commission lorsque vous achetez par l'intermédiaire de ces liens.
  1. Acer Aspire 5100 Fan Replacement, Fan: étape 1, image 1 de 1
    • Flip the laptop upside-down.
    • Remove the battery as a safety precaution.
    • Remove the four screws attached to the large panel.
  2. Acer Aspire 5100 Fan Replacement: étape 2, image 1 de 1
    • Lift and remove the panel.
  3. Acer Aspire 5100 Fan Replacement: étape 3, image 1 de 1
    • Remove the two screws attached to the fan.
  4. Acer Aspire 5100 Fan Replacement: étape 4, image 1 de 2 Acer Aspire 5100 Fan Replacement: étape 4, image 2 de 2
    • Lift the fan and detach the cable that connects the fan to the motherboard.
    • The fan can break easily. Be careful when removing.
    • When detaching the cable, do not pull on the cable itself. Instead, use a small spudger to detach it at the white section that connects it to the motherboard.
4 autres ont terminé cette réparation.
Brad Rollinson
Membre depuis le 09/29/10
1 113 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team 14-39, Forte Fall 2010 Membre de l'équipe Cal Poly, Team 14-39, Forte Fall 2010
CPSU-FORTE-F10S14G39
5 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 29
Total : 15,108
