Aller au contenu principal
Acer Iconia A100 Light Sensor  Replacement
Bree Abernathy
Bree Abernathy et un autre contributeur
Dernière mise à jour le May 11, 2017
10 - 15 minutes
Modérée
Use this step-by-step guide to replace the Light Sensor Module on your Acer Iconia Tab A100.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Acer Iconia A100 Light Sensor  Replacement, Battery: étape 1, image 1 de 1
    • Start at any side of the tablet.
    • Begin to take apart the tablet with a plastic opening tool along the sides of the tablet.
    • Work your way around the tablet.
    • There are four side pieces in total.
  2. Acer Iconia A100 Light Sensor  Replacement: étape 2, image 1 de 1
    • Remove the five 4 mm screws from the edges of the tablet with a Phillips #00 screwdriver.
  3. Acer Iconia A100 Light Sensor  Replacement: étape 3, image 1 de 1
    • Carefully separate the back piece from the device using a plastic opening tool.
    • Remember to open along the entire perimeter of the tablet.
  4. Acer Iconia A100 Light Sensor  Replacement: étape 4, image 1 de 1
    • Turn the tablet over so that the battery is facing upwards.
    • Remove the four 4mm screws located around the battery.
  5. Acer Iconia A100 Light Sensor  Replacement: étape 5, image 1 de 2 Acer Iconia A100 Light Sensor  Replacement: étape 5, image 2 de 2
    • Use the tip of a plastic spudger or opening tool to gently push the connector head out of its socket.
    • Use your fingers or the flat edge of a plastic opening tool to lift the battery up and off of the device.
    • Be sure to not have any water around the device while removing the battery.
    • Be sure to be cautious while removing the battery and remove carefully; avoid ripping the wires attached to the battery.
  6. Acer Iconia A100 Light Sensor  Replacement, I/O Board: étape 6, image 1 de 1
    • Gently peel off any tape securing the FPC to the main plate.
  7. Acer Iconia A100 Light Sensor  Replacement: étape 7, image 1 de 3 Acer Iconia A100 Light Sensor  Replacement: étape 7, image 2 de 3 Acer Iconia A100 Light Sensor  Replacement: étape 7, image 3 de 3
    • Locate the two connectors at each end of the FPC.
    • Use the flat edge of a spudger tool or your fingernail to gently pry each connector straight upwards out of its socket, then remove the FPC cable from the unit.
    • While a metal spudger tool is shown here, it is best to use a plastic spudger / opening tool when possible, and only use a metal spudger as a last resort!
    • You should now see the yellow-colored strip on the metal base marking the location of the FPC
  8. Acer Iconia A100 Light Sensor  Replacement: étape 8, image 1 de 1
    • Locate the L-shaped I/O Board.
    • Locate the gray 3G Antenna wire.
    • If the gray 3G Antenna wire is connected to your I/O Board, disconnect it. If for some reason the 3G Antenna wire is already disconnected from the I/O Board (as it was in this device) simply lift it out of the way.
  9. Acer Iconia A100 Light Sensor  Replacement: étape 9, image 1 de 2 Acer Iconia A100 Light Sensor  Replacement: étape 9, image 2 de 2
    • Locate the microphone cable.
    • You should be able to gently pull it out of its socket using only your fingers.
    • The spudger is used in the photo merely to hold up / identify the disconnected mic cable head.
  10. Acer Iconia A100 Light Sensor  Replacement: étape 10, image 1 de 3 Acer Iconia A100 Light Sensor  Replacement: étape 10, image 2 de 3 Acer Iconia A100 Light Sensor  Replacement: étape 10, image 3 de 3
    • Locate the light sensor connector.
    • Use the tip of a spudger or your fingernail to lift up and flip the small retaining flap on the connector. The light sensor ribbon cable should now be free, so simply pull it out.
    • This is a ZIF (zero insertion force) connector, which requires no force to remove / plug in the connector.
    • Please make sure you lift up on the small retaining flap on the connector, not the connector itself!
    • Use a Phillips #00 screwdriver to unscrew the single 3.0mm Phillips screw next to the light sensor connector.
  11. Acer Iconia A100 Light Sensor  Replacement: étape 11, image 1 de 2 Acer Iconia A100 Light Sensor  Replacement: étape 11, image 2 de 2
    • Carefully lift the I/O Board off the device.
  12. Acer Iconia A100 Light Sensor  Replacement, Light Sensor: étape 12, image 1 de 2 Acer Iconia A100 Light Sensor  Replacement, Light Sensor: étape 12, image 2 de 2
    • To remove the light sensor, use the flat edge of a spudger, plastic opening tool, or your fingernail to gently pry the top of the square connector straight up and out of its socket.
Bree Abernathy
Membre depuis le 03/01/17
341 Réputation
3 tutoriels rédigés
Équipe
IUPUI, Team S1-G4, Harley Spring 2017 Membre de l'équipe IUPUI, Team S1-G4, Harley Spring 2017
IUPUI-HARLEY-S17S1G4
4 membres
4 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 145
