Aller au contenu principal
Acer Iconia One 7 Battery Replacement
Ahmad Kayali
Ahmad Kayali et 8 autres contributeurs
Dernière mise à jour le March 4, 2024
Aucune estimation
Modérée
Outils incorrects
Détails manquants
The battery is essential to the Acer Iconia One 7 as it powers the entire device. One should be careful when replacing a battery because it may be dangerous if the battery is punctured. Taking apart the battery itself without proper safety precautions could prove to be hazardous to one’s health. Power down the device before beginning this repair.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Acer Iconia One 7 Battery Replacement, Battery: étape 1, image 1 de 1
    • Begin prying the front from the back on any side of the tablet. Gently work your way around the tablet with the prying tool.
  2. Acer Iconia One 7 Battery Replacement: étape 2, image 1 de 1
    • Using a plastic opening tool, separate the back cover from the main device.
    • Open each side continuously to ensure all sides have been separated.
  3. Acer Iconia One 7 Battery Replacement: étape 3, image 1 de 1
    • Turn the tablet over so the battery is facing up.
  4. Acer Iconia One 7 Battery Replacement: étape 4, image 1 de 2 Acer Iconia One 7 Battery Replacement: étape 4, image 2 de 2
    • Carefully pull back the black tape covering the battery lead connector.
    • Disconnect connection with the board by pulling up on the wire with the plastic opening tool.
  5. Acer Iconia One 7 Battery Replacement: étape 5, image 1 de 3 Acer Iconia One 7 Battery Replacement: étape 5, image 2 de 3 Acer Iconia One 7 Battery Replacement: étape 5, image 3 de 3
    Outil utilisé dans cette étape :
    Plastic Cards
    $2.99
    • Using a plastic card or opening pick, separate the battery from the rest of the device.
    • Do not use a metal spudger like seen in the example photos. Use a plastic card to avoid bending or rupturing the battery.
6 autres ont terminé cette réparation.
Ahmad Kayali
Membre depuis le 09/01/15
458 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team 8-5, Eyestone Fall 2015 Membre de l'équipe USF Tampa, Team 8-5, Eyestone Fall 2015
USFT-EYESTONE-F15S8G5
3 membres
5 tutoriels rédigés
4 commentaires
is there a replacement batt that can fit here or other brand that can fit? like from samsing tab? acer battery sucks
Stanley So - Réponse
Thank you for this guide, replaced my battery (very easy with guide) and now my tablet works good. Also saved me some money. Thanks
vlamar14 - Réponse
My acer iconia one 7 battery model is 308292 wnd there is no tutorial regarding replacing battery. Thank
wantalktasol - Réponse
Where I can order the new battery part?
melanieloa3 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 28
30 derniers jours : 35
Total : 18,529
