Aller au contenu principal
Acer Iconia Tab A500 Screen Replacement
Kyle Libby
Kyle Libby et 8 autres contributeurs
Dernière mise à jour le October 17, 2016
25 - 30 minutes
Modérée
This guide will provide step by step instructions on how to replace the screen on an Acer Iconia Tab A500.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Acer Iconia Tab A500 Screen Replacement, Back Case: étape 1, image 1 de 1
    • To start, gently separate one corner of the case using the black spudger.
  2. Acer Iconia Tab A500 Screen Replacement: étape 2, image 1 de 1
    • Once you have successfully pried the spudger in between the front case and back case, continue do so around the entire tablet until the back case is completely disconnected.
  3. Acer Iconia Tab A500 Screen Replacement, Battery: étape 3, image 1 de 1
    • Remove the 5mm screws that are securing the battery to the rest of the tablet.
    • Use the Phillips #00 Screwdriver to remove the 5mm screws.
  4. Acer Iconia Tab A500 Screen Replacement: étape 4, image 1 de 1
    • Use the sharper end of the spudger to disconnect the battery from the mother board.
    • The battery connector will slide off.
  5. Acer Iconia Tab A500 Screen Replacement, Speakers: étape 5, image 1 de 1
    • Locate the 4 screws and cable that hold in the two speakers.
    • Use the Phillips #1 screwdriver to remove these 2mm black screws.
    • Remove the 2mm silver screws.
    • Not all 4 screws are going to be the same kind. This will not affect the speaker replacement.
  6. Acer Iconia Tab A500 Screen Replacement: étape 6, image 1 de 2 Acer Iconia Tab A500 Screen Replacement: étape 6, image 2 de 2
    • Carefully remove the connector cable by pushing on the rim of black plastic insert.
  7. Acer Iconia Tab A500 Screen Replacement: étape 7, image 1 de 1
    • Unfortunately, the top speaker is a wedged under the motherboard.
    • To get this speaker out, use the spudger and gently pry it out.
  8. Acer Iconia Tab A500 Screen Replacement, Power Button: étape 8, image 1 de 1
    • Using the Phillips #1 screwdriver, remove the screws near the edges of the tablet.
    • They may be different sizes, the silver are 5mm and the black are 2mm.
  9. Acer Iconia Tab A500 Screen Replacement: étape 9, image 1 de 1
    • Lift up on the black flaps to release the flat cables.
    • Pull this Connector off.
  10. Acer Iconia Tab A500 Screen Replacement: étape 10, image 1 de 1
    • Use the spudger to detach the indicated cables.
    • Remove the last motherboard screw under the rightmost cable. It is a silver 5mm.
  11. Acer Iconia Tab A500 Screen Replacement: étape 11, image 1 de 1
    • Disconnect the two gold connectors by pulling straight up on them with your fingers.
    • Like before, lift up on the black flap to detach the cable.
  12. Acer Iconia Tab A500 Screen Replacement: étape 12, image 1 de 1
    • Having disconnected all those pesky cables, the motherboard lifts cleanly out.
  13. Acer Iconia Tab A500 Screen Replacement, Screen: étape 13, image 1 de 1
    • Remove this components near the edge of the tablet by unscrewing the 5mm screw holding the top in place.
  14. Acer Iconia Tab A500 Screen Replacement: étape 14, image 1 de 1
    • Lift the silver case, exposing the back side of the screen.
  15. Acer Iconia Tab A500 Screen Replacement: étape 15, image 1 de 1
    • Use the spudger to pry off the screen, it is held in by a film of glue around the rim.
  16. Acer Iconia Tab A500 Screen Replacement: étape 16, image 1 de 1
    • Swap the screen and you're finished!
7 autres ont terminé cette réparation.
Kyle Libby
Membre depuis le 04/07/14
1 006 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team 7-23, Regan Spring 2014 Membre de l'équipe Cal Poly, Team 7-23, Regan Spring 2014
CPSU-REGAN-S14S7G23
4 membres
19 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 9
Total : 13,088
