Aller au contenu principal
Acer Nitro 5 AN517-51-56YW Battery Replacement
Jacob Elkins
Jacob Elkins et 3 autres contributeurs
Dernière mise à jour le December 15, 2022
1 - 5 minutes
Facile
Use this guide to replace the battery of an Acer Nitro 5 AN517-51-56YW. The AN517 is a gaming laptop that houses a higher-performance battery. Make sure to know exactly which battery type and specifications you will need to replace the battery. If you notice that the battery is swollen, please visit this article on how to identify a swollen battery and what to do.
This guide will help ensure the laptop can start up and will be repaired.
Ce dont vous avez besoin
Pièces
Outils
  • Phillips #1 Screwdriver
  • Spudger
    Spudger
Afficher plus…
  1. Acer Nitro 5 AN517-51-56YW Battery Replacement, Bottom Cover: étape 1, image 1 de 3 Acer Nitro 5 AN517-51-56YW Battery Replacement, Bottom Cover: étape 1, image 2 de 3 Acer Nitro 5 AN517-51-56YW Battery Replacement, Bottom Cover: étape 1, image 3 de 3
    • Place the laptop upside-down so that the fans are facing away from you.
    • Remove the twelve 6.7 mm screws from the bottom cover using a Phillips #1 screwdriver.
    • Pry the bottom cover away from the laptop using a spudger.
  2. Acer Nitro 5 AN517-51-56YW Battery Replacement, Battery: étape 2, image 1 de 2 Acer Nitro 5 AN517-51-56YW Battery Replacement, Battery: étape 2, image 2 de 2
    • Unplug the connection plug that attaches the battery to the motherboard.
    • Make sure to pull the connector safely so that it doesn't break.
    • Remove the two 4.7 mm screws using a Phillips #1 screwdriver.
  3. Acer Nitro 5 AN517-51-56YW Battery Replacement: étape 3, image 1 de 2 Acer Nitro 5 AN517-51-56YW Battery Replacement: étape 3, image 2 de 2
    • Remove the battery from the laptop.
    • Make sure that your laptop powers on before you begin reassembly. If it does not start, make sure the battery is firmly connected to the motherboard.
2 autres ont terminé cette réparation.
Jacob Elkins
Membre depuis le 09/15/22
221 Réputation
1 tutoriel rédigé
Équipe
University of Memphis, Team 3-1, Lane Fall 2022 Membre de l'équipe University of Memphis, Team 3-1, Lane Fall 2022
UM-LANE-F22S3G1
5 membres
4 tutoriels rédigés
0Commentaires sur le guide
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 39
Total : 2,242
