Acer Spin 5 SP515-51GN-807G Fan Replacement
Introduction
Passez à l'étape 1If the device is overheating or a heat warning is being displayed on the screen, you should consider using this guide to replace the cooling fans.
It is important to have a properly functioning fan to ensure your laptop runs efficiently, as it provides cooling to the laptop, especially during periods of high usage. If the fan is blocked or not properly running, you will notice that the fan is not sufficiently cooling the laptop.
A cause of poor fan performance could be due to a blockage caused by dust or other debris. It is possible to try and remove the dust using a dust blower.
Always remember to power down the device before beginning replacement.
Ce dont vous avez besoin
Remove the eleven 6.5 mm screws that secure the back case using a Phillips #1 screwdriver.
Outil utilisé dans cette étape :Tweezers$4.99
Using tweezers, remove the piece of black tape over the battery cable connector.
Grip the battery cable on both sides with your fingertips and gently pull it away from the port.
Great work with clear, specific directions here and a nice flipbook shot. This step would be easy to follow.
Remove the piece of tape covering the fan screw using a pair of tweezers.
1 commentaire de tutoriel
is there any way for you to do a screen replacement guild for the Acer Spin 5 SP515-51GN-807G ?
