Alienware 17 R4 Solid State Drive (SSD) Replacement
Introduction
Passez à l'étape 1This guide will show you how to access and remove the solid state drive (SSD) for your Alienware 17 R4.
Ce dont vous avez besoin
Kits de réparation
Ces kits contiennent toutes les pièces et tous les outils nécessaires à la réalisation du tutoriel.
Pièces
Outils
Afficher plus…
Use a PH1 screwdriver bit to remove the six M2.5x13 screws (2.4 mm) on the back of the laptop.
Use a PH1 screwdriver bit to loosen the one M2x3 screw (1.9 mm).
Pull the base cover up to remove it.
If you are having trouble, insert a plastic opening tool into the divots along the laptop's edges to loosen.
pulled the battery cable let it sit for ten minutes and my no post problem was fixed
thanks -
Disconnect the battery connector cable, located on the right side of the laptop, above the hard disk drive.
Slide the solid state drive towards yourself to prevent damage to the card.
How do I copy the contents of the old SSD to a new SSD. For example if I’m booting from my old SSD but want to update to a larger SSD.
Shouldn’t step 1 be preserving my data? I give you a low score for lack of forethought. Guess another website might have pertinent information.
3 autres ont terminé cette réparation.
1 commentaire de tutoriel
Is it advised to pull the HDD before pulling the SSD or is this guide just written in a way to cover how to remove both of them?
