Anbernic RG35XX Screen Replacement
Introduction
Passez à l'étape 1The screen in the Anbernic RG35xx is responsible for displaying games/software. If your screen isn't functioning properly, this guide demonstrates how to replace your screen.
Ce dont vous avez besoin
Outils
Afficher plus…
Remove the SD card located on the right side of the device by pushing into the SD card slot and pulling the card out.
Remove the six 1.2 mm screws that secure the back case with a 2.5 Hex Bit screwdriver.
Use your fingernails or tweezers to gently remove the battery connector from its socket.
Disconnect the red audio cable from its motherboard port by carefully pulling the connector with your index finger and thumb or with fine tip tweezers.
Use a hair dryer to gently heat the rear of the screen until it's almost too hot to touch.
Insert a jimmy between the screen and plastic bracket. Once a slim gap is opened, insert an opening pick between the plastic bracket and rear screen.
Continue to insert opening picks around the entire perimeter of the screen as you pry to avoid the adhesive from reengaging.
Once the screen fully releases, remove it.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
