Aller au contenu principal
Anbernic RG35XX Speaker Replacement
Katie Cabrera
Katie Cabrera et 2 autres contributeurs
Dernière mise à jour le December 30, 2024
15 minutes
Modérée
The speaker allows audio from the device, however, overtime the speaker may stop working due to damage from dirt and dust or long-term use of the high volume. This guide demonstrates how to replace the speaker.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Anbernic RG35XX Speaker Replacement, Rear Case: étape 1, image 1 de 2 Anbernic RG35XX Speaker Replacement, Rear Case: étape 1, image 2 de 2
    • Remove the SD card located on the right side of the device by pushing into the SD card slot and pulling the card out.
    • Remove the six 1.2 mm screws that secure the back case with a 2.5 Hex Bit screwdriver.
  2. Anbernic RG35XX Speaker Replacement: étape 2, image 1 de 1
    • Insert an opening tool into the MicroSD card slot and twist it clockwise to begin releasing the rear case.
    • You'll hear "clicks" as the retaining clips release.
    • Pry around the entire perimeter until the rear case fully releases.
    • Remove the rear case.
  3. Anbernic RG35XX Speaker Replacement, Anbernic RG35XX Battery Disconnection: étape 3, image 1 de 2 Anbernic RG35XX Speaker Replacement, Anbernic RG35XX Battery Disconnection: étape 3, image 2 de 2
    • Use your fingernails or tweezers to gently remove the battery connector from its socket.
  4. Anbernic RG35XX Speaker Replacement, Motherboard: étape 4, image 1 de 1
    • Disconnect the red audio cable from its motherboard port by carefully pulling the connector with your index finger and thumb or with fine tip tweezers.
  5. Anbernic RG35XX Speaker Replacement: étape 5, image 1 de 1
    • Remove the six 1 mm Phillips screws that secure the motherboard to the case.
  6. Anbernic RG35XX Speaker Replacement: étape 6, image 1 de 3 Anbernic RG35XX Speaker Replacement: étape 6, image 2 de 3 Anbernic RG35XX Speaker Replacement: étape 6, image 3 de 3
    • Flip up the black ZIF locking flap that secures the bronze ribbon cable.
    • Gently disconnect the bronze ribbon cable.
    • Lift the motherboard up and out the chassis.
  7. Anbernic RG35XX Speaker Replacement, Speaker: étape 7, image 1 de 2 Anbernic RG35XX Speaker Replacement, Speaker: étape 7, image 2 de 2
    • Take a pair of angled tweezers and put it in the square hole next to the tweezers.
    • Rotate the tweezer tip clockwise to push the speaker out of the chassis.
    • Remove the speaker.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Katie Cabrera
Membre depuis le 08/28/24
490 Réputation
4 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 16
30 derniers jours : 59
Total : 148
