Aller au contenu principal
Aranet 4 Display Replacement
spoofer
spoofer et un autre contributeur
Dernière mise à jour le January 18, 2025
10 minutes
Facile
Tutoriel réalisé par la communauté
Replacing the display on the Aranet 4 Home
The aranet 4 uses a 1.54 inch (3.9 centimeters) E-ink display, when dropped the glass on the back of the screen can break causing the display to be stuck on whatever was last shown.
Ce dont vous avez besoin
iFixit touche une commission lorsque vous achetez par l'intermédiaire de ces liens.
  1. Aranet 4 Display Replacement, Disassembly: étape 1, image 1 de 2 Aranet 4 Display Replacement, Disassembly: étape 1, image 2 de 2
    • Remove the battery door and the batteries.
    • Unscrew the two T6 screws.
    • Turn your device over so that the screen faces you and remove the cover.
  2. Aranet 4 Display Replacement, Removing the old screen: étape 2, image 1 de 3 Aranet 4 Display Replacement, Removing the old screen: étape 2, image 2 de 3 Aranet 4 Display Replacement, Removing the old screen: étape 2, image 3 de 3
    • Pull back the screen.
    • Carefully release the display ribbon cable by, depending on your board revision either lifting the brown cover on the flip-up connector or sliding out the stuffer actuator connector. (Refer to the images for clarification.)
    • Remove the old screen.
  3. Aranet 4 Display Replacement, Placing new screen: étape 3, image 1 de 1
    • Insert the new screen's cable into the connector (black side up).
    • Carefully place the front cover back and reassemble the device.
It is not necessary to remove the the board from the bottom-case, if you do wish to do this be carefull not to break the battery terminals!
2 autres ont terminé cette réparation.
spoofer
Membre depuis le 06/11/24
137 Réputation
1 tutoriel rédigé
6 commentaires de tutoriel
Great info and instruction. But….. amazone does not ship to The Netherlands.
Cees Doets - Réponse
Hi Cees,
You can look for products sold on amazon in different countries using the ASIN number.
Here's a link for the Netherlands: https://www.amazon.nl/dp/B071HW4Z6N
Good luck with your repair!
spoofer -
Thanks a lot! Great info.
Yes yes yes. Both my Aranet’s work again.
Thanks for the guide! I successfully repaired my Aranet4 by following it. A couple of notes:
- I was able to get a better price than Amazon for the replacement display at https://www.waveshare.com/product/displa....
- The connector for the flexible printed circuit board on my model didn't flip up, but instead slides forward. I found documentation for the connector (or something very very similar to it) here: https://www.te.com/content/dam/te-com/do... (search for "Stuffer Actuator (Plunger Style)")
Jon Manning - Réponse
Thanks for the information, I have updated the guide to include the stuffer actuator connector!
As for the display, I have added the black and white version off the display you provided to the Item table. (waveshare.com/1.54inch-e-paper.htm)
spoofer -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 21
Total : 267
