Aller au contenu principal
Asus Chromebook C523N Battery Replacement
Aaron Hogan
Aaron Hogan et 4 autres contributeurs
Dernière mise à jour le January 10, 2023
5 - 10 minutes
Facile
If the Asus Chromebook C523N battery life is extremely short, the unit will not charge, or turn on use this guide to replace the battery.
Before using this guide, check to make sure that the laptop will not charge and that the charger is working.
To begin replacing the battery, make sure that the laptop is powered off and disconnected from any power source.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Asus Chromebook C523N Battery Replacement, Back Cover: étape 1, image 1 de 2 Asus Chromebook C523N Battery Replacement, Back Cover: étape 1, image 2 de 2
    • Remove the four 0.5mm JIS #00 screws from the bottom edge of the Chromebook and one in the center.
    • Remove the six 1.7mm JIS #00 screws from the sides and top edge of the Chromebook.
  2. Asus Chromebook C523N Battery Replacement: étape 2, image 1 de 2 Asus Chromebook C523N Battery Replacement: étape 2, image 2 de 2
    • Using a spudger, lift the top left base pad and remove it to reveal a final screw underneath.
    • Remove the one 0.5mm JIS #00 screw underneath the base pad.
  3. Asus Chromebook C523N Battery Replacement: étape 3, image 1 de 2 Asus Chromebook C523N Battery Replacement: étape 3, image 2 de 2
    • Use an opening tool to gently pry the base enclosure up and remove from the laptop.
  4. Asus Chromebook C523N Battery Replacement, Battery: étape 4, image 1 de 3 Asus Chromebook C523N Battery Replacement, Battery: étape 4, image 2 de 3 Asus Chromebook C523N Battery Replacement, Battery: étape 4, image 3 de 3
    • To disconnect the cable, use the tip of a spudger or your fingernail to flip up the small locking flap.
    • Gently disconnect the battery cable from the motherboard.
  5. Asus Chromebook C523N Battery Replacement: étape 5, image 1 de 2 Asus Chromebook C523N Battery Replacement: étape 5, image 2 de 2
    • Remove six 1.4 mm JIS #00 screws from the battery.
  6. Asus Chromebook C523N Battery Replacement: étape 6, image 1 de 1
    • Remove the battery from the laptop.
9 autres ont terminé cette réparation.
Aaron Hogan
Membre depuis le 10/15/19
682 Réputation
4 tutoriels rédigés
3 commentaires
Hi, thank you for this tutorial.
I’ve tried to remove the battery myself but I’ve made a mistake on step 4 while trying to disconnect the cord from the motherboard. By pushing too hard, i’ve unsoldered from the motherboard the black item the cord plugs into. Do you think it can be soldered back by a professional ? If not, can it be replaced ? Thanks in advance,
Julien Guézennec - Réponse
Hi, the %#*@ same thing happened to me too. Could u solve it with a professional?
Regards
Mike Soup -
Hey, I replaced the battery is a new one, but when I plug it in the orange light starts flashing but the laptop does start and when I plug in the charger it keeps flashing. Don't know what the problem is. It did work without a battery for a while because I had to order it, can someone help?
Christopher Verbist - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 9
7 derniers jours : 31
30 derniers jours : 84
Total : 9,693
