Asus Q552UB-BHI7T12 RAM Replacement
Introduction
Passez à l'étape 1RAM (Random Access Memory) is also known as system memory. Generally, 12 GB (8 GB and 4 GB) RAM is given by default with the Asus Q552UB-BHI7T12 Laptop. But users can upgrade up to 16 GB using two 8 GB RAMs. Normally the user needs to change the RAM when its performance degrades therefore the system becomes slower. But before changing the RAM, an Asus Q552UB-BHI7T12 user needs to confirm here that it’s actually the RAM which is causing the problem, not the CPU or Graphics Card.
Use this simple guide to replace your Asus Q552UB-BHI7T12 RAM. Follow these three simple steps which will take no longer than 10 minutes.
On the bottom of the laptop, gently pull the wire connecting the battery to the motherboard
To reassemble device, follow the instructions in reverse order.
