Asus Transformer Flip Book TP200S WiFi Card Replacement
Introduction
Passez à l'étape 1Are you unable to connect to any WiFi connection? If so, then you might be experiencing a faulty WiFi card. This guide will take you through all the steps required to replace your Asus Flip Book WiFi card.
Ce dont vous avez besoin
Outil utilisé dans cette étape :Tweezers$4.99
The battery comes attached to the motherboard and needs to be disconnected before you can remove it.
Disconnect the battery from the motherboard by gently pulling out the connection with tweezers.
Gently remove the Wifi cables hooked to the rim of the battery
Remove the battery
