Asus Z54C-JS31 Display Replacement
Introduction
Passez à l'étape 1The display is vital to using a laptop. If the display is damaged or not functioning properly this guide will show how to replace it.
Ce dont vous avez besoin
Turn the laptop upside down so that the underside is facing up and locate the two switches that are on each side of the battery.
Slide the switch on the top right corner to the right.
Slide and hold the switch on the top left corner to the left and carefully remove the battery.
Outil utilisé dans cette étape :Tweezers$4.99
Open up the laptop and locate the two circular stickers at the bottom corners of the display.
Use a pair of tweezers to remove the two black stickers covering the screws.
Using a Philips #000 screwdriver, remove the two 9mm screws.
