Aller au contenu principal
Asus Z54C-JS31 Hard Drive Replacement
Mark DeSimone
Mark DeSimone et un autre contributeur
Dernière mise à jour le December 21, 2017
7 minutes
Facile
The hard drive is important for storing the computer's data and may need to be replaced or upgraded to increase the amount of storage space.
Ce dont vous avez besoin
Outils
  1. Asus Z54C-JS31 Hard Drive Replacement, Battery: étape 1, image 1 de 3 Asus Z54C-JS31 Hard Drive Replacement, Battery: étape 1, image 2 de 3 Asus Z54C-JS31 Hard Drive Replacement, Battery: étape 1, image 3 de 3
    • Turn the laptop upside down so that the underside is facing up and locate the two switches that are on each side of the battery.
    • Slide the switch on the top right corner to the right.
    • Slide and hold the switch on the top left corner to the left and carefully remove the battery.
  2. Asus Z54C-JS31 Hard Drive Replacement, HDD/RAM Cover Panel: étape 2, image 1 de 2 Asus Z54C-JS31 Hard Drive Replacement, HDD/RAM Cover Panel: étape 2, image 2 de 2
    • Use a Phillips #000 screwdriver to remove the two 9mm screws from the HDD/RAM cover panel.
  3. Asus Z54C-JS31 Hard Drive Replacement: étape 3, image 1 de 2 Asus Z54C-JS31 Hard Drive Replacement: étape 3, image 2 de 2
    • Slide the back panel off by placing a hand on each corner and pulling the panel towards you.
  4. Asus Z54C-JS31 Hard Drive Replacement, Hard Drive: étape 4, image 1 de 2 Asus Z54C-JS31 Hard Drive Replacement, Hard Drive: étape 4, image 2 de 2
    • Remove the four 9mm screws holding the hard drive in place.
  5. Asus Z54C-JS31 Hard Drive Replacement: étape 5, image 1 de 3 Asus Z54C-JS31 Hard Drive Replacement: étape 5, image 2 de 3 Asus Z54C-JS31 Hard Drive Replacement: étape 5, image 3 de 3
    • Slide the hard drive to the left to disconnect it.
    • Then pull on the black tab to lift the hard drive out of the laptop.
Mark DeSimone
Membre depuis le 10/19/17
801 Réputation
8 tutoriels rédigés
Équipe
UMass Dartmouth, Team S3-G1, Bailey Fall 2017 Membre de l'équipe UMass Dartmouth, Team S3-G1, Bailey Fall 2017
UMASSD-BAILEY-F17S3G1
2 membres
8 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 143
