Aller au contenu principal
Asus ZenBook UX303U Screen Assembly Replacement
Dean Anderson
Dean Anderson et 4 autres contributeurs
Dernière mise à jour le June 14, 2018
10 - 15 minutes
Modérée
This guide will show you how to replace the screen on an Asus ZenBook UX303U laptop.
Ce dont vous avez besoin
Outils
  1. Asus ZenBook UX303U Screen Assembly Replacement, Back Panel: étape 1, image 1 de 1
    • Remove the two round rubber feet at the hinge-edge of the laptop.
  2. Asus ZenBook UX303U Screen Assembly Replacement: étape 2, image 1 de 1
    • Remove the eleven 4 mm Phillips #00 screws from the back panel.
  3. Asus ZenBook UX303U Screen Assembly Replacement: étape 3, image 1 de 2 Asus ZenBook UX303U Screen Assembly Replacement: étape 3, image 2 de 2
    • Using a plastic opening tool pry the back panel off of the laptop.
  4. Asus ZenBook UX303U Screen Assembly Replacement, Screen Assembly: étape 4, image 1 de 2 Asus ZenBook UX303U Screen Assembly Replacement, Screen Assembly: étape 4, image 2 de 2
    • Remove cable connecting the screen assembly to the the motherboard.
  5. Asus ZenBook UX303U Screen Assembly Replacement: étape 5, image 1 de 3 Asus ZenBook UX303U Screen Assembly Replacement: étape 5, image 2 de 3 Asus ZenBook UX303U Screen Assembly Replacement: étape 5, image 3 de 3
    • Remove the three 4mm Phillips #00 screws in the hinge to loosen the motherboard fan.
    • Lift the hinge up.
    • It is not necessary to remove the motherboard fan to replace the screen assembly.
  6. Asus ZenBook UX303U Screen Assembly Replacement: étape 6, image 1 de 1
    • Remove the three Phillips #00 screws securing the hinge to the IO board.
  7. Asus ZenBook UX303U Screen Assembly Replacement: étape 7, image 1 de 2 Asus ZenBook UX303U Screen Assembly Replacement: étape 7, image 2 de 2
    • Remove the Wi-Fi card by pulling it straight out of its connector.
  8. Asus ZenBook UX303U Screen Assembly Replacement: étape 8, image 1 de 2 Asus ZenBook UX303U Screen Assembly Replacement: étape 8, image 2 de 2
    • Lift the entire lower assembly up and off of the hinges securing it into place.
7 autres ont terminé cette réparation.
Dean Anderson
Membre depuis le 02/14/18
630 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team S3-G5, Nance Spring 2018 Membre de l'équipe USF Tampa, Team S3-G5, Nance Spring 2018
USFT-NANCE-S18S3G5
3 membres
9 tutoriels rédigés
6 commentaires de tutoriel
If anyone knows of a good, reliable source to buy a replacement screen assembly let me know, please. I have a 303U with the 1800 screen and I accidentally sat something heavy enough on top of the laptop to crack the screen on the right-third of the screen. I can’t use half of the touch screen and it’s fairly obvious depending on the color/brightness of the content I’m looking at. Would like to be able to replace this and these steps are pretty easy for me to follow so I’m confident I can have a newish looking laptop again if I can find a replacement screen.
chris.schroeder86 - Réponse
Hi ! Did you manage to find one? I’m trying to do the same thing :)
Adrien Rousseau -
The bottom of the pictured device may feature Phillips #00 screws, but I also have this laptop and the screws around the edge of the bottom panel are Torx T5s on my device.
Nick Brennan - Réponse
It seems that the hinge assembly on one side is broken on my UX303U, on the screen side of the hinge. Do I need to replace the whole screen assembly? The laptop works perfectly otherwise.
Kobus - Réponse
Same here, asus ux303u screen side hinge is stuffed. But I think it may actually be the plastic screen cover itself where the hinge attaches, not just the hinge.
Dash OShea - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 42
Total : 8,293
