Aller au contenu principal
Brother CS6000i Sewing Light Replacement
Aidan Lear
Aidan Lear et 3 autres contributeurs
Dernière mise à jour le December 31, 2024
15 minutes
Modérée
If your Brother CS6000i sewing light is flickering, dim, or not working at all, use this guide to replace the old LED light.
Before you begin, inspect the light for any debris or build up on the bulb. If the bulb is dirty, this could cause it to illuminate less. Make sure this is not the case before disassembling the sewing machine.
Step 5 requires you to remove the light wiring from the PSU. A faulty connection beforehand could be the reason for the light not working. Make sure that the faulty connection is not the issue before buying a new part to replace the light system.
Before beginning, make sure the sewing machine is not connected to any power.
Ce dont vous avez besoin
iFixit touche une commission lorsque vous achetez par l'intermédiaire de ces liens.
  1. Brother CS6000i Sewing Light Replacement, Body: étape 1, image 1 de 2 Brother CS6000i Sewing Light Replacement, Body: étape 1, image 2 de 2
    • Remove the five 20 mm Phillips #2 screws on the back of the device.
    • Remove the single 28 mm Phillips #2 screw on the back of the device.
    • Remove the single 23 mm Phillips #2 screw on the back of the device.
  2. Brother CS6000i Sewing Light Replacement: étape 2, image 1 de 2 Brother CS6000i Sewing Light Replacement: étape 2, image 2 de 2
    • Pull the white cover off.
  3. Brother CS6000i Sewing Light Replacement: étape 3, image 1 de 2 Brother CS6000i Sewing Light Replacement: étape 3, image 2 de 2
    • Remove the final screw, a 11 mm Phillips #2.
    • After removing all eight screws, you will have five 2 mm screws, one 28 mm screw, one 23 mm screw, and one 11 mm screw, all of which are Phillips #2.
  4. Brother CS6000i Sewing Light Replacement: étape 4, image 1 de 3 Brother CS6000i Sewing Light Replacement: étape 4, image 2 de 3 Brother CS6000i Sewing Light Replacement: étape 4, image 3 de 3
    • Slightly pull apart the two halves of the machine, taking care not to strain the attached cables.
    • Unhook the white wires that are connected to the motherboard.
    • Fully separate the two halves.
  5. Brother CS6000i Sewing Light Replacement, Sewing Light: étape 5, image 1 de 1
    • Use a Phillips #2 screwdriver to remove the single 16 mm Phillips #2 screw.
    • Remove the metal plate.
  6. Brother CS6000i Sewing Light Replacement: étape 6, image 1 de 1
    • Use a Phillips #2 screwdriver to remove the two 16 mm Phillips #2 screws.
    • Remove the metal plate underneath screws once screws are removed.
  7. Brother CS6000i Sewing Light Replacement: étape 7, image 1 de 1
    • Use a standoff tip to remove the 10 mm Phillips #2 screw directly next to the lightbulb.
  8. Brother CS6000i Sewing Light Replacement: étape 8, image 1 de 1
    • Disconnect the light connector from the PCB.
  9. Brother CS6000i Sewing Light Replacement: étape 9, image 1 de 1
    • Remove the light.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Aidan Lear
Membre depuis le 10/31/24
121 Réputation
1 tutoriel rédigé
Équipe
Cuesta, Team 20-1, Krynen Fall 2024 Membre de l'équipe Cuesta, Team 20-1, Krynen Fall 2024
CUESTA-KRYNEN-F24S20G1
5 membres
8 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 29
Total : 91
