CHUWI GemiBook XPro Fan Replacement
Introduction
Passez à l'étape 1The CHUWI GemiBook XPro may have overheating issues which may cause damage to the CPU and other components which could be caused by a defective fan. This step-by-step guide can be immediately followed after the Battery Replacement Guide regarding opening up this device. The tools required for this guide are the Spudger and a Philips 1 screwdriver. Please refer to our Fan Troubleshooting page for an extended list of symptoms and alternative solutions.
Ce dont vous avez besoin
Orient the device to where you can see the bottom of the case.
Use a Phillips #1 screwdriver to remove the twelve 5.6 mm screws that secure the lower case.
