Aller au contenu principal
Canon PowerShot G7X Motherboard Replacement
Brandon Lacy
Brandon Lacy et 2 autres contributeurs
Dernière mise à jour le December 20, 2019
10 - 15 minutes
Modérée
The motherboard functions as the central hub for all of the components in your device. If one or more components cease to function, the motherboard may be faulty. Follow the directions in this guide to replace the motherboard in your device.
Ce dont vous avez besoin
Pièces
Outils
Afficher plus…
  1. Canon PowerShot G7X Motherboard Replacement, Dial: étape 1, image 1 de 1
    • Remove the five 2mm Phillips #000 screws that are under the screen of the camera.
  2. Canon PowerShot G7X Motherboard Replacement: étape 2, image 1 de 1
    • Remove the two 3mm Phillips #000 screws under the AV-out digital flap.
    • Remove the two 3 mm Phillips #000 screws from the side of the camera.
  3. Canon PowerShot G7X Motherboard Replacement: étape 3, image 1 de 1
    • Remove the two 3 mm Phillips #000 screws on the side of camera with the flash toggle.
  4. Canon PowerShot G7X Motherboard Replacement: étape 4, image 1 de 1
    • Remove the four 4 mm Phillips #000 screws from the plate on the bottom of the camera.
  5. Canon PowerShot G7X Motherboard Replacement: étape 5, image 1 de 1
    • Remove the back plate.
  6. Canon PowerShot G7X Motherboard Replacement: étape 6, image 1 de 1
    • Remove the three 3 mm Phillips #000 screws around the dial.
  7. Canon PowerShot G7X Motherboard Replacement: étape 7, image 1 de 2 Canon PowerShot G7X Motherboard Replacement: étape 7, image 2 de 2
    • Using the nylon spudger, gently lift the ZIF tab.
    • Disconnect the ribbon cable that connects the dial to the motherboard.
    • Remove the dial from the device.
  8. Canon PowerShot G7X Motherboard Replacement, Flash: étape 8, image 1 de 2 Canon PowerShot G7X Motherboard Replacement, Flash: étape 8, image 2 de 2
    • Remove the three, blue 5 mm Phillips screws from the back plate.
    • Remove seven 2 mm Phillips #000 screws.
  9. Canon PowerShot G7X Motherboard Replacement: étape 9, image 1 de 2 Canon PowerShot G7X Motherboard Replacement: étape 9, image 2 de 2
    • While using the plastic opening tool, gently pry the top plate off the camera.
  10. Canon PowerShot G7X Motherboard Replacement: étape 10, image 1 de 2 Canon PowerShot G7X Motherboard Replacement: étape 10, image 2 de 2
    • Using the black nylon spudger, gently lift the ribbon cable connected to the LCD screen housing until it comes out then remove the housing.
  11. Canon PowerShot G7X Motherboard Replacement: étape 11, image 1 de 2 Canon PowerShot G7X Motherboard Replacement: étape 11, image 2 de 2
    • Remove the 2 mm Phillips #000 screw underneath the top plate.
    • Remove silver plate.
  12. Canon PowerShot G7X Motherboard Replacement: étape 12, image 1 de 1
    • Take the Phillips #000 and remove the three 5 mm screws from the front plate.
  13. Canon PowerShot G7X Motherboard Replacement: étape 13, image 1 de 2 Canon PowerShot G7X Motherboard Replacement: étape 13, image 2 de 2
    • Using the spudger, gently lift the ribbon cable from underneath the front plate.
    • Remove the front plate.
  14. Canon PowerShot G7X Motherboard Replacement: étape 14, image 1 de 2 Canon PowerShot G7X Motherboard Replacement: étape 14, image 2 de 2
    • Remove flash toggle plate.
    • Remove the 2mm Phillips #000 screws under the flash toggle.
  15. Canon PowerShot G7X Motherboard Replacement: étape 15, image 1 de 2 Canon PowerShot G7X Motherboard Replacement: étape 15, image 2 de 2
    • Flash contains charged capacitor. Shock hazard.
    • Using the black nylon spudger, gently lift the ribbon cable that connects the flash to motherboard and remove the flash from the device.
  16. Canon PowerShot G7X Motherboard Replacement, Lens: étape 16, image 1 de 1
    • Remove the 5 mm Phillips #000 screw from the copper plate.
  17. Canon PowerShot G7X Motherboard Replacement: étape 17, image 1 de 1
    • Using the black nylon spudger, lift the ribbon cable gently until it comes out.
  18. Canon PowerShot G7X Motherboard Replacement: étape 18, image 1 de 1
    • Remove the copper plate to reveal connections to the lens.
  19. Canon PowerShot G7X Motherboard Replacement: étape 19, image 1 de 1
    • Using the black nylon spudger, lift gently on the pin connector until it comes off.
  20. Canon PowerShot G7X Motherboard Replacement: étape 20, image 1 de 2 Canon PowerShot G7X Motherboard Replacement: étape 20, image 2 de 2
    • Using the spudger, gently lift on the ribbon cable until it comes out.
    • Separate the lens from the motherboard.
  21. Canon PowerShot G7X Motherboard Replacement, Motherboard: étape 21, image 1 de 1
    • Remove the 5 mm Phillips #000 silver, anchor screws from the corners of the motherboard marked in the picture.
  22. Canon PowerShot G7X Motherboard Replacement: étape 22, image 1 de 1
    • Remove motherboard.
Brandon Lacy
Membre depuis le 11/06/19
119 Réputation
1 tutoriel rédigé
Équipe
IUPUI, Team S1-G5, Stella Fall 2019 Membre de l'équipe IUPUI, Team S1-G5, Stella Fall 2019
IUPUI-STELLA-F19S1G5
3 membres
5 tutoriels rédigés
Un commentaire
Very Good!
I Think I Want to DIY Rep My DC
sheep free - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 28
Total : 910
