Aller au contenu principal
Canon PowerShot S410 LCD Screen Replacement
kubayubay
kubayubay et 11 autres contributeurs
Dernière mise à jour le December 6, 2024
35 - 55 minutes
Difficile
If your Canon PowerShot S410 is displaying distorted images or no image at all, it might be time to replace the LCD screen. Follow this step-by-step guide to restore your camera’s functionality.
The LCD screen plays a crucial role in translating visual input from the lens into a clear image that you can view. A malfunctioning or damaged LCD can lead to distorted visuals or a blank screen, making it difficult to capture the perfect shot.
Before diving into the repair, take a moment to check the camera settings. Press the DISP button on your Canon PowerShot S410 to ensure the display is enabled and that the issue isn’t just a simple setting error.
To complete this repair, you'll need a Phillips #0 screwdriver and a pair of tweezers. Don’t worry—no prior experience is necessary, and this process is straightforward.
As you work with the tools, handle everything gently to avoid causing further damage to your camera. Some steps will involve carefully pulling a ribbon cable to detach components, so proceed with caution.
Ready to get started? Let’s go!
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Canon PowerShot S410 LCD Screen Replacement, Battery: étape 1, image 1 de 2 Canon PowerShot S410 LCD Screen Replacement, Battery: étape 1, image 2 de 2
    • Turn the camera with the bottom side facing up.
    • Locate the panel labeled "Batt. Open"
    • Place your finger on the panel and slide it in the direction of the arrow.
    • The slot will swing open revealing the battery pack.
  2. Canon PowerShot S410 LCD Screen Replacement: étape 2, image 1 de 1
    • Pull the orange lever and the battery will spring out slightly.
  3. Canon PowerShot S410 LCD Screen Replacement: étape 3, image 1 de 2 Canon PowerShot S410 LCD Screen Replacement: étape 3, image 2 de 2
    • Grasp the battery and fully pull it out of its slot.
    • When placing the new battery back in the slot, the arrow on the battery must align with the arrow on the camera.
  4. Canon PowerShot S410 LCD Screen Replacement, Back Cover: étape 4, image 1 de 1
    • Start by laying the camera flat with the LCD screen facing up.
    • Using the Phillips #0 screwdriver, remove the 3.8mm screw in the upper right corner.
  5. Canon PowerShot S410 LCD Screen Replacement: étape 5, image 1 de 1
    • Position the camera with the bottom facing up.
    • Twist the screwdriver counter-clockwise to remove the 4.8mm screw.
    • Repeat to remove the two 2.3mm screws.
  6. Canon PowerShot S410 LCD Screen Replacement: étape 6, image 1 de 2 Canon PowerShot S410 LCD Screen Replacement: étape 6, image 2 de 2
    • Position the camera so that the rubber "AV Out Digital" tab is facing upward.
    • Slide the rubber tab to reveal the bottom screw.
    • Using the screwdriver, remove the two 3.7mm screws.
  7. Canon PowerShot S410 LCD Screen Replacement: étape 7, image 1 de 1
    • Turn the camera with the back side facing you.
    • Grip the edges of the back plate, and carefully slide it off.
    • If there is any resistance in movement, double check there are no screws left in the chassis.
  8. Canon PowerShot S410 LCD Screen Replacement, Front Cover: étape 8, image 1 de 2 Canon PowerShot S410 LCD Screen Replacement, Front Cover: étape 8, image 2 de 2
    • Orient the camera as in the picture.
    • Remove the two 2.3mm outer screws using the Phillips #0 screwdriver.
    • Remove the two 3.8mm screws near the strap bracket.
    • Remove the small panel covering the mounting bracket.
    • Remove the door covering the memory card.
  9. Canon PowerShot S410 LCD Screen Replacement: étape 9, image 1 de 1
    • Rotate the camera so that the bottom side is facing you.
    • Remove the 3.8mm screw below the mounting bracket using the Phillips screwdriver.
  10. Canon PowerShot S410 LCD Screen Replacement: étape 10, image 1 de 1
    • Rotate the camera so that the front is facing you.
    • Grasp the sides of the front cover and carefully pull the front panel off of the camera.
  11. Canon PowerShot S410 LCD Screen Replacement, LCD Screen: étape 11, image 1 de 2 Canon PowerShot S410 LCD Screen Replacement, LCD Screen: étape 11, image 2 de 2
    • Position the camera so that the motherboard is facing you.
    • A fingernail or spudger can be used to remove the plastic flap covering the motherboard.
  12. Canon PowerShot S410 LCD Screen Replacement: étape 12, image 1 de 2 Canon PowerShot S410 LCD Screen Replacement: étape 12, image 2 de 2
    • Turn the camera so that the bottom side is facing you.
    • Remove the 2.1mm screw using the Phillips #0 screwdriver
    • Grab the sides of the bottom panel and lift to expose the ribbon cable.
  13. Canon PowerShot S410 LCD Screen Replacement: étape 13, image 1 de 2 Canon PowerShot S410 LCD Screen Replacement: étape 13, image 2 de 2
    Outil utilisé dans cette étape :
    • Turn the camera so that the motherboard is facing you.
    • Using your fingernail, open the black clip holding the ribbon cable.
    • Gently pull out the ribbon cable in the direction of the cable using your fingers or tweezers.
  14. Canon PowerShot S410 LCD Screen Replacement: étape 14, image 1 de 1
    • Turn the camera so that the LCD screen is facing you.
    • Remove the two 2.1mm screws on the aluminum tabs of the LCD screen using a screwdriver.
  15. Canon PowerShot S410 LCD Screen Replacement: étape 15, image 1 de 2 Canon PowerShot S410 LCD Screen Replacement: étape 15, image 2 de 2
    • Using a pair of tweezers, carefully pull the top ribbon cable out of the slot.
    • Grasp the sides of the LCD screen and lift off of the camera.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
kubayubay
Membre depuis le 01/23/11
101 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 11-27, Maness Winter 2011 Membre de l'équipe Cal Poly, Team 11-27, Maness Winter 2011
CPSU-MANESS-W11S11G27
4 membres
7 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 28
Total : 3,676
