Aller au contenu principal
Canon PowerShot SD1200 IS LCD Replacement
Jeff Casper
Jeff Casper et 5 autres contributeurs
Dernière mise à jour le May 7, 2024
5 minutes
Modérée
Découpez pour améliorer
Removing the LCD screen seems intimidating, but everything comes apart rather easily. You just have to lift tabs, remove a single screw and lift out the screen.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Canon PowerShot SD1200 IS LCD Replacement, Front and Rear Covers: étape 1, image 1 de 1
    • Remove the battery.
  2. Canon PowerShot SD1200 IS LCD Replacement: étape 2, image 1 de 3 Canon PowerShot SD1200 IS LCD Replacement: étape 2, image 2 de 3 Canon PowerShot SD1200 IS LCD Replacement: étape 2, image 3 de 3
    • Remove the two screws from the side of the camera casing with the strap. (4mm Phillips 00)
    • Remove the two screws from the bottom of the camera. (4mm Phillips 00)
    • Remove the two screws from the right side of the camera opposite the strap. (2mm Phillips 00)
  3. Canon PowerShot SD1200 IS LCD Replacement: étape 3, image 1 de 2 Canon PowerShot SD1200 IS LCD Replacement: étape 3, image 2 de 2
    • Pull off the front cover.
    • If the top of the cover sticks, use gentle downward pressure on the retention clips above the lens to release.
    • Remove the back cover.
    It should be pointed out that the retention clips are loosened by pressing a pointed object, like a spudger point, into the tiny blind holes around the edge of the painted part of the front case.
    hjd7y - Réponse
  4. Canon PowerShot SD1200 IS LCD Replacement, LCD: étape 4, image 1 de 3 Canon PowerShot SD1200 IS LCD Replacement, LCD: étape 4, image 2 de 3 Canon PowerShot SD1200 IS LCD Replacement, LCD: étape 4, image 3 de 3
    Outil utilisé dans cette étape :
    • Use the spudger to lift the retaining flap on the Zero Insertion Force (ZIF) tab securing the thick ribbon cable.
    • Slide out the ribbon cable using fingers or tweezers.
    • Be sure you are prying up on the hinged retaining flap, not the connector.
    • Using tweezers, disconnect the small ribbon cable below the flash assembly from the No Fuss Connector by simply pulling the ribbon cable straight out.
  5. Canon PowerShot SD1200 IS LCD Replacement: étape 5, image 1 de 3 Canon PowerShot SD1200 IS LCD Replacement: étape 5, image 2 de 3 Canon PowerShot SD1200 IS LCD Replacement: étape 5, image 3 de 3
    • Remove the L shaped brackets from the left and right side of the LCD screen with the spudger tool.
    • The Brackets have tabs that need to be pried up.
    • Remove the screw below the shutter button. (2.5mm Phillips 00)
    • Holding the sides of the LCD screen, lift the screen up and away to remove.
Jeff Casper
Membre depuis le 09/15/16
860 Réputation
7 tutoriels rédigés
Équipe
USF Tampa, Team 17-5, Blackwell Fall 2016 Membre de l'équipe USF Tampa, Team 17-5, Blackwell Fall 2016
USFT-BLACKWELL-F16S17G5
3 membres
7 tutoriels rédigés
1 commentaire de tutoriel
Hello do you guys sello the LCD screen and do you ship to México.
Killer King - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 24
Total : 688
