Aller au contenu principal
Canon PowerShot SD1400 IS Image Capture Button Replacement
Braxton Beal
Braxton Beal et 5 autres contributeurs
Dernière mise à jour le October 15, 2018
30 - 35 minutes
Modérée
The image capture button can break or become stuck. This guide details how to replace the image capture button and the surrounding plastic housing on the Canon PowerShot SD1400 IS camera.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Canon PowerShot SD1400 IS Image Capture Button Replacement, Image Capture Button: étape 1, image 1 de 2 Canon PowerShot SD1400 IS Image Capture Button Replacement, Image Capture Button: étape 1, image 2 de 2
    • Use a Phillips #00 driver to remove the four 2.0 mm Phillips screws on the camera housing.
    • There are two screws on either side.
  2. Canon PowerShot SD1400 IS Image Capture Button Replacement: étape 2, image 1 de 1
    • Use a Phillips #1 driver to remove the one 4.0 mm Phillips screw located on the bottom of the camera.
  3. Canon PowerShot SD1400 IS Image Capture Button Replacement: étape 3, image 1 de 1
    • Remove the face housing from the body of the camera.
  4. Canon PowerShot SD1400 IS Image Capture Button Replacement: étape 4, image 1 de 1
    • Turn the camera over and remove the rear housing.
  5. Canon PowerShot SD1400 IS Image Capture Button Replacement: étape 5, image 1 de 1
    • Remove the button panel if it did not fall out on its own.
  6. Canon PowerShot SD1400 IS Image Capture Button Replacement: étape 6, image 1 de 1
    • Use a Phillips #0 driver to remove the one 3.0 mm Phillips copper screw from the top of the camera.
    • This screw is only visible after the front and rear panels have been removed.
  7. Canon PowerShot SD1400 IS Image Capture Button Replacement: étape 7, image 1 de 1
    • Use a Phillips #0 driver to remove the one 3.0 mm Phillips silver screw from the rear face of the camera.
  8. Canon PowerShot SD1400 IS Image Capture Button Replacement: étape 8, image 1 de 1
    • Use a plastic spudger to lift the golden film off of the microchip on the front face of the camera, exposing a screw.
  9. Canon PowerShot SD1400 IS Image Capture Button Replacement: étape 9, image 1 de 1
    • Use a Phillips #0 driver to remove the one 3.0 mm Phillips screw.
  10. Canon PowerShot SD1400 IS Image Capture Button Replacement: étape 10, image 1 de 2 Canon PowerShot SD1400 IS Image Capture Button Replacement: étape 10, image 2 de 2
    • Use a metal spudger to carefully pry the small black tab away from the connector that secures one end of the golden film.
    • When fully released, the small black tab will stand up straight from the face of the camera and the golden film will no longer be secured.
  11. Canon PowerShot SD1400 IS Image Capture Button Replacement: étape 11, image 1 de 1
    • Carefully insert a metal spudger under the two clusters of wires that are plugged into the small chip on the face of the camera.
    • One cluster of wires is red, the other cluster is black.
    • Pull the wires parallel to the face of the camera to disconnect them from the small chip.
  12. Canon PowerShot SD1400 IS Image Capture Button Replacement: étape 12, image 1 de 1
    • The image capture button housing can now be removed from the body of the camera and replaced.
Follow these instructions in reverse order to reassemble the device.
Braxton Beal
Membre depuis le 01/30/18
702 Réputation
3 tutoriels rédigés
Équipe
Baylor, Team S1-G3, Johnson Spring 2018 Membre de l'équipe Baylor, Team S1-G3, Johnson Spring 2018
BU-JOHNSON-S18S1G3
3 membres
4 tutoriels rédigés
1 commentaire de tutoriel
Where can do you buy replacement parts?
Chase Mahard - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 11
Total : 337
