Aller au contenu principal
Canon PowerShot SD1400 IS User Interface Panel Replacement
Braxton Beal
Braxton Beal et 4 autres contributeurs
Dernière mise à jour le September 18, 2019
10 - 15 minutes
Facile
The buttons on the user interface panel can become broken or stuck. This guide will show how to replace the user interface panel on the Canon PowerShot SD1400 IS.
Ce dont vous avez besoin
Pièces
Outils
Afficher plus…
  1. Canon PowerShot SD1400 IS User Interface Panel Replacement, User Interface Panel: étape 1, image 1 de 3 Canon PowerShot SD1400 IS User Interface Panel Replacement, User Interface Panel: étape 1, image 2 de 3 Canon PowerShot SD1400 IS User Interface Panel Replacement, User Interface Panel: étape 1, image 3 de 3
    • Remove the four 2.0 mm Phillips screws of the camera using the J00 bit from the 54-bit Driver Kit. There are two screws on both sides.
  2. Canon PowerShot SD1400 IS User Interface Panel Replacement: étape 2, image 1 de 1
    • Remove the 4.0 mm Phillips screw located on the bottom of the camera.
  3. Canon PowerShot SD1400 IS User Interface Panel Replacement: étape 3, image 1 de 1
    • Remove the front face panel of the camera by hand using firm pressure.
    • If one point of the face is stuck to the body, check if there is a screw preventing the front face from coming off.
  4. Canon PowerShot SD1400 IS User Interface Panel Replacement: étape 4, image 1 de 1
    • Remove the rear panel of the camera by hand using firm pressure.
  5. Canon PowerShot SD1400 IS User Interface Panel Replacement: étape 5, image 1 de 1
    • Remove the user interface panel by hand. The panel may fall out on its own, this is normal.
    • Replace the user interface panel by setting it in position.
2 autres ont terminé cette réparation.
Braxton Beal
Membre depuis le 01/30/18
702 Réputation
3 tutoriels rédigés
Équipe
Baylor, Team S1-G3, Johnson Spring 2018 Membre de l'équipe Baylor, Team S1-G3, Johnson Spring 2018
BU-JOHNSON-S18S1G3
3 membres
4 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 4
Total : 346
