Aller au contenu principal
Canon PowerShot SD700 LCD screen Replacement
Emilio Rossi
Emilio Rossi et 5 autres contributeurs
Dernière mise à jour le January 28, 2014
10 - 15 minutes
Modérée
Tutoriel vedette
Follow these steps to remove and install a new LCD screen.
Ce dont vous avez besoin
Outils
  • Spudger
    Spudger
  • Phillips #00 Screwdriver
Afficher plus…
  1. Canon PowerShot SD700 LCD screen Replacement, Outside Case: étape 1, image 1 de 1
    • Turn off the camera by pressing the power button above the LCD screen.
  2. Canon PowerShot SD700 LCD screen Replacement: étape 2, image 1 de 1
    • Remove the two small screws on the bottom of the camera using a Phillips #00 screwdriver.
  3. Canon PowerShot SD700 LCD screen Replacement: étape 3, image 1 de 1
    • Use a Phillips #00 screwdriver to remove the two small screws on the right side of the camera.
  4. Canon PowerShot SD700 LCD screen Replacement: étape 4, image 1 de 1
    • Use a Phillips #00 screwdriver to remove the screw on the left of the camera under the A/V out digital label.
  5. Canon PowerShot SD700 LCD screen Replacement: étape 5, image 1 de 1
    • Use a Phillips #00 screwdriver to remove the screw on the bottom of the camera near the battery and memory card slots.
    • This screw will be longer than the rest of the screws.
  6. Canon PowerShot SD700 LCD screen Replacement: étape 6, image 1 de 1
    • Remove the front, back, and side casings from the camera and set to the side.
  7. Canon PowerShot SD700 LCD screen Replacement, LCD screen: étape 7, image 1 de 1
    • Remove the two screws that connect the LCD and backlight to the main body of the camera.
  8. Canon PowerShot SD700 LCD screen Replacement: étape 8, image 1 de 3 Canon PowerShot SD700 LCD screen Replacement: étape 8, image 2 de 3 Canon PowerShot SD700 LCD screen Replacement: étape 8, image 3 de 3
    • Gently pry the LCD and the backlight from the main body of the camera.
    • Gently pry the LCD from the backlight.
    • The thin ribbon cable is for the backlight.
    • The thick ribbon cable is for the LCD screen.
  9. Canon PowerShot SD700 LCD screen Replacement: étape 9, image 1 de 1
    • Carefully lift the ZIF connector that covers the thick ribbon cable.
    • This ZIF connector is fragile. Use caution when lifting it from its down position.
    • Insert the new LCD and reassemble the camera.
2 autres ont terminé cette réparation.
Emilio Rossi
Membre depuis le 04/07/11
113 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 9-71, Walters Spring 2011 Membre de l'équipe Cal Poly, Team 9-71, Walters Spring 2011
CPSU-WALTERS-S11S9G71
4 membres
9 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 21
Total : 2,733
