Aller au contenu principal
Canon PowerShot SD700 Outside Case Replacement
Emilio Rossi
Emilio Rossi et 8 autres contributeurs
Dernière mise à jour le January 9, 2025
5 - 10 minutes
Modérée
This guide will help you remove and replace the outside case of the Canon PowerShot SD700. Follow the step-by-step instructions to remove the outside case of your Canon PowerShot SD700. You will need Phillips #00 screwdriver to complete the steps throughout the guide.
Ce dont vous avez besoin
Outils
  1. Canon PowerShot SD700 Outside Case Replacement, Outside Case: étape 1, image 1 de 1
    • Turn off the camera by pressing the power button above the LCD screen.
  2. Canon PowerShot SD700 Outside Case Replacement: étape 2, image 1 de 1
    • Remove the two small screws on the bottom of the camera using a Phillips #00 screwdriver.
  3. Canon PowerShot SD700 Outside Case Replacement: étape 3, image 1 de 1
    • Use a Phillips #00 screwdriver to remove the two small screws on the right side of the camera.
  4. Canon PowerShot SD700 Outside Case Replacement: étape 4, image 1 de 1
    • Use a Phillips #00 screwdriver to remove the screw on the left of the camera under the A/V out digital label.
  5. Canon PowerShot SD700 Outside Case Replacement: étape 5, image 1 de 1
    • Use a Phillips #00 screwdriver to remove the screw on the bottom of the camera near the battery and memory card slots.
    • This screw will be longer than the rest of the screws.
  6. Canon PowerShot SD700 Outside Case Replacement: étape 6, image 1 de 1
    • Remove the front, back, and side casings from the camera and set to the side.
To reassemble your device, follow steps 1-6 instructions in reverse order.
3 autres ont terminé cette réparation.
Emilio Rossi
Membre depuis le 04/07/11
113 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 9-71, Walters Spring 2011 Membre de l'équipe Cal Poly, Team 9-71, Walters Spring 2011
CPSU-WALTERS-S11S9G71
4 membres
9 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 3
Total : 1,496
