Aller au contenu principal
Canon PowerShot SX50 HS Function Dial Replacement
Remington Goodwin
Remington Goodwin et 4 autres contributeurs
Dernière mise à jour le June 23, 2015
2 minutes
Très facile
Replace the func. set turn dial of the Canon PowerShot SX50 HS.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Canon PowerShot SX50 HS Function Dial Replacement, Battery: étape 1, image 1 de 1
    • Locate the battery compartment on the bottom of the camera.
    • Push the latch on the outside of the battery door to the right to get to the battery pack inside.
  2. Canon PowerShot SX50 HS Function Dial Replacement: étape 2, image 1 de 1
    • Pull the brown latch on the inside of the battery door towards your palm (to the left). The battery pack should pop out (battery not pictured).
    • Now remove the battery pack from the camera with your fingers.
  3. Canon PowerShot SX50 HS Function Dial Replacement, Rear Case: étape 3, image 1 de 2 Canon PowerShot SX50 HS Function Dial Replacement, Rear Case: étape 3, image 2 de 2
    • Remove the two Phillips #000 screws, length 5 mm, on either side of the viewfinder.
    • Remove the one Phillips #000 screw, length 4 mm, on the bottom, closer to the back side of the camera.
  4. Canon PowerShot SX50 HS Function Dial Replacement: étape 4, image 1 de 2 Canon PowerShot SX50 HS Function Dial Replacement: étape 4, image 2 de 2
    • Remove the two Phillips #000 screws, length 3 mm, on the left side of camera.
    • Remove the Phillips #000 screw, length 4 mm, located between the two 3 mm screws.
    • Remove the two Phillips #000 screws, length 4 mm, on the bottom left corner of the camera.
  5. Canon PowerShot SX50 HS Function Dial Replacement: étape 5, image 1 de 1
    • Find the "A/V Out Digital" charging station and lift up the flap.
    • Remove the two Phillips #000 screws, length 5 mm, that are under the "A/V Out Digital" flap.
    • Remove the one Phillips #000 screw, length 5 mm, that is outside the "A/V Out Digital" flap.
  6. Canon PowerShot SX50 HS Function Dial Replacement: étape 6, image 1 de 2 Canon PowerShot SX50 HS Function Dial Replacement: étape 6, image 2 de 2
    • Use the plastic opening tool to carefully start lifting up the camera's left-side panel. Then use your fingers to pry off the rest.
  7. Canon PowerShot SX50 HS Function Dial Replacement: étape 7, image 1 de 3 Canon PowerShot SX50 HS Function Dial Replacement: étape 7, image 2 de 3 Canon PowerShot SX50 HS Function Dial Replacement: étape 7, image 3 de 3
    • Make sure the LCD screen panel, the battery compartment door, and the 'A/V Out Digital" flap are all open.
    • Using your fingers, carefully pry off the back encasement (you may need to use a plastic opening tool to help you).
    • Do not remove the back casing too far or too quickly. There is a wire ribbon attaching the back encasement to the motherboard that is very delicate.
  8. Canon PowerShot SX50 HS Function Dial Replacement: étape 8, image 1 de 3 Canon PowerShot SX50 HS Function Dial Replacement: étape 8, image 2 de 3 Canon PowerShot SX50 HS Function Dial Replacement: étape 8, image 3 de 3
    Outil utilisé dans cette étape :
    • Find the orange wire ribbon attaching the back encasement to the I/O board in the lower right-hand corner of the camera (lens facing away).
    • Carefully lift up the brown clip holding the wire ribbon in place and pull the ribbon out of the clasp with your fingers or tweezers.
    • Be cautious when the removing the wire ribbon; it is very delicate.
    I broke the brown clip…..now what to do?
    Edward - Réponse
  9. Canon PowerShot SX50 HS Function Dial Replacement: étape 9, image 1 de 1
    • Now you can completely separate the back encasement from the rest of the camera.
  10. Canon PowerShot SX50 HS Function Dial Replacement, Function Dial: étape 10, image 1 de 1
    • Remove the four Phillips #000 screws, length 3 mm, attaching the metal panel to the inside of the back encasement.
  11. Canon PowerShot SX50 HS Function Dial Replacement: étape 11, image 1 de 2 Canon PowerShot SX50 HS Function Dial Replacement: étape 11, image 2 de 2
    • Take off the metal plate with your fingers.
2 autres ont terminé cette réparation.
Remington Goodwin
Membre depuis le 04/02/15
250 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 12-7, Lancaster Spring 2015 Membre de l'équipe Cal Poly, Team 12-7, Lancaster Spring 2015
CPSU-LANCASTER-S15S12G7
5 membres
7 tutoriels rédigés
2 commentaires de tutoriel
Interested to know where I can buy the switch/ribbon assembly for that function dial?
Liz Comery - Réponse
I appreciated the clear instructions and photos. Couldn’t be any better. Now I would like to know where to purchase the dial assembly.
Rita McLachlan - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 20
Total : 1,300
