Aller au contenu principal
Canon PowerShot SX530 HS  Display Replacement
Xavier Patrick
Xavier Patrick et 2 autres contributeurs
Dernière mise à jour le October 24, 2022
15 minutes
Modérée
This guide shows how to replace the Display Screen for the PowerShot SX530 HS.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Canon PowerShot SX530 HS  Display Replacement, Battery: étape 1, image 1 de 1
    • Flip the camera upside down to find the battery compartment (marked CARD/ BATT. OPEN).
    • Press into the grooves of the battery door and slide the panel in the direction of the arrow.
  2. Canon PowerShot SX530 HS  Display Replacement: étape 2, image 1 de 1
    • Gently press down on the orange release button found inside.
    • After pressing the release button, pull the battery out of the camera.
  3. Canon PowerShot SX530 HS  Display Replacement, Canon PowerShot SX530 HS Back Panel Assembly: étape 3, image 1 de 2 Canon PowerShot SX530 HS  Display Replacement, Canon PowerShot SX530 HS Back Panel Assembly: étape 3, image 2 de 2
    • Flip over the camera.
    • Use a Phillips PH000 to remove the two 4mm screws near the center of the camera.
    • Use a Phillips PH000 to remove the two 6mm screws on the ends of the camera.
  4. Canon PowerShot SX530 HS  Display Replacement: étape 4, image 1 de 2 Canon PowerShot SX530 HS  Display Replacement: étape 4, image 2 de 2
    • Locate the left side of the camera.
    • Use a Philips PH000 to remove the two 6mm screws.
  5. Canon PowerShot SX530 HS  Display Replacement: étape 5, image 1 de 2 Canon PowerShot SX530 HS  Display Replacement: étape 5, image 2 de 2
    • Rotate the camera to the side with the removable cover containing the HDMI and mini USB ports.
    • Use the Phillips PH000 to remove the 7mm screw located next to the HDMI port. This screw has red loctite.
    • Use the Phillips PH000 to remove the 4mm screw near the USB port.
    • Use the Phillips PH000 to remove the 7.4mm screw near the USB port.
    Is the marking for the 4mm screw and 7mm screw at the correct position on step five?
    Paul K - Réponse
    This previous markup has been adjusted. The 4mm screw is in between the two outer screws.
    nicO -
  6. Canon PowerShot SX530 HS  Display Replacement: étape 6, image 1 de 3 Canon PowerShot SX530 HS  Display Replacement: étape 6, image 2 de 3 Canon PowerShot SX530 HS  Display Replacement: étape 6, image 3 de 3
    • Rotate the camera to locate the side with the LCD screen.
    • Use a Phillips PH000 to remove the two 6mm screws above the LCD screen.
    • Once the screws are out the back panel, it is ready to be taken off. Grip the backside of the camera and pull it away evenly on every side. The backside must come off straight from the front.
  7. Canon PowerShot SX530 HS  Display Replacement, Internal Button Sensor Plate: étape 7, image 1 de 2 Canon PowerShot SX530 HS  Display Replacement, Internal Button Sensor Plate: étape 7, image 2 de 2
    • Locate the Internal Button Sensor Plate. This is the white and silver plate to the right of the LCD Display.
    • Use a Phillips PH000 to remove the two 3mm screws on the panel.
    • Use a Phillips PH000 to remove the 3mm screw connected to the motherboard.
  8. Canon PowerShot SX530 HS  Display Replacement: étape 8, image 1 de 2 Canon PowerShot SX530 HS  Display Replacement: étape 8, image 2 de 2
    • Peel off the plate. Be careful, as the plate is connected to the motherboard underneath by a ribbon.
    • Use a plastic opening tool to unlock the ribbon tape.
    • Remove the ribbon tape from the motherboard.
  9. Canon PowerShot SX530 HS  Display Replacement, LCD Display: étape 9, image 1 de 2 Canon PowerShot SX530 HS  Display Replacement, LCD Display: étape 9, image 2 de 2
    • Locate the Display screen in the center of the camera.
    • Use a plastic opening tool to pry off the LCD screen. Start on the bottom left corner—this is the furthest away from the ribbon holding it down on the right side.
    • The adhesive holding down the display should be strong enough to put the display back on.
  10. Canon PowerShot SX530 HS  Display Replacement: étape 10, image 1 de 1
    Hi,
    i’ve bought only the LCD screen cause my backlight is OK. Is possible to separate LCD from backlight in a way to substitute the damaged LCD with a new one? Which way? Thanks a lot for your support.
    Gianluca Costabile - Réponse
    I don't believe there's an easy way to separate the two. This display unit is only attached by the single ribbon cable and adhesive, so fortunately the swap is easy.
    Did you buy a standalone LCD without the backlight?
    nicO -
4 autres ont terminé cette réparation.
Xavier Patrick
Membre depuis le 02/02/17
481 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team 16-4, Blackwell Spring 2017 Membre de l'équipe USF Tampa, Team 16-4, Blackwell Spring 2017
USFT-BLACKWELL-S17S16G4
4 membres
9 tutoriels rédigés
1 commentaire de tutoriel
What LCD screen u used
Frank Spencer - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 29
Total : 2,682
