Aller au contenu principal
Capresso Infinity Bottom Conical Burr Replacement
Nina Mackin
Nina Mackin et 2 autres contributeurs
Dernière mise à jour le May 19, 2020
20 minutes
Facile
If you need to replace the bottom conical burr, follow this guide to access it. The bottom conical burr is essential to having finely ground coffee, and if it is dull or no longer working, it needs to be replaced. For this guide you will need a Torx Security T20 Bit Screwdriver and an extension bit. To access the bottom conical burr, you will need to follow previous guides on replacing the outside metal casing. This guide is simple once you’ve finished the other.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Capresso Infinity Bottom Conical Burr Replacement, Metal Outside Casing: étape 1, image 1 de 2 Capresso Infinity Bottom Conical Burr Replacement, Metal Outside Casing: étape 1, image 2 de 2
    • Twist the top plastic container to the left counterclockwise.
    • Pull upwards to remove.
  2. Capresso Infinity Bottom Conical Burr Replacement: étape 2, image 1 de 3 Capresso Infinity Bottom Conical Burr Replacement: étape 2, image 2 de 3 Capresso Infinity Bottom Conical Burr Replacement: étape 2, image 3 de 3
    • Twist the top burr to the left counter clockwise.
  3. Capresso Infinity Bottom Conical Burr Replacement: étape 3, image 1 de 2 Capresso Infinity Bottom Conical Burr Replacement: étape 3, image 2 de 2
    • Flip entire device upside down.
    • Remove two rubber coverings on the back of the device.
  4. Capresso Infinity Bottom Conical Burr Replacement: étape 4, image 1 de 2 Capresso Infinity Bottom Conical Burr Replacement: étape 4, image 2 de 2
    • Remove four 11.59mm T10 screws.
    • The screws will have small circular washers under them. Put them aside for reassembly.
  5. Capresso Infinity Bottom Conical Burr Replacement: étape 5, image 1 de 3 Capresso Infinity Bottom Conical Burr Replacement: étape 5, image 2 de 3 Capresso Infinity Bottom Conical Burr Replacement: étape 5, image 3 de 3
    • Lift the metal outside casing off the black base.
    • Flip the outside casing forward so you have access to the inside of it.
  6. Capresso Infinity Bottom Conical Burr Replacement: étape 6, image 1 de 3 Capresso Infinity Bottom Conical Burr Replacement: étape 6, image 2 de 3 Capresso Infinity Bottom Conical Burr Replacement: étape 6, image 3 de 3
    • Remove one 11.59mm T10 screw.
    • Let the green wire fall, or place somewhere so it doesn't get in the way.
    • There will be a small metal retainer and washer, put them aside for reassembly.
  7. Capresso Infinity Bottom Conical Burr Replacement: étape 7, image 1 de 3 Capresso Infinity Bottom Conical Burr Replacement: étape 7, image 2 de 3 Capresso Infinity Bottom Conical Burr Replacement: étape 7, image 3 de 3
    • Remove two 11.59mm T10 screws.
  8. Capresso Infinity Bottom Conical Burr Replacement: étape 8, image 1 de 2 Capresso Infinity Bottom Conical Burr Replacement: étape 8, image 2 de 2
    • Remove the time/on switch by pulling upwards.
  9. Capresso Infinity Bottom Conical Burr Replacement, Bottom Conical Burr: étape 9, image 1 de 2 Capresso Infinity Bottom Conical Burr Replacement, Bottom Conical Burr: étape 9, image 2 de 2
    • Grab the edge of the plastic black ring that sits on top of the device and gently pull up to release.
  10. Capresso Infinity Bottom Conical Burr Replacement: étape 10, image 1 de 2 Capresso Infinity Bottom Conical Burr Replacement: étape 10, image 2 de 2
    • Remove the black rubber knob atop the bottom burr by gently pulling up.
  11. Capresso Infinity Bottom Conical Burr Replacement: étape 11, image 1 de 3 Capresso Infinity Bottom Conical Burr Replacement: étape 11, image 2 de 3 Capresso Infinity Bottom Conical Burr Replacement: étape 11, image 3 de 3
    • Partially remove one 47.20mm T20 screw.
    • The screw does not need to come out completely, it just needs to be loose enough pull the burr out of the device.
  12. Capresso Infinity Bottom Conical Burr Replacement: étape 12, image 1 de 2 Capresso Infinity Bottom Conical Burr Replacement: étape 12, image 2 de 2
    • Remove the bottom burr piece by pulling upwards.
    • There will be 3 springs and 3 metal balls under the springs, located underneath the burr. Put them aside for reassembly.
  13. Capresso Infinity Bottom Conical Burr Replacement: étape 13, image 1 de 2 Capresso Infinity Bottom Conical Burr Replacement: étape 13, image 2 de 2
    • Remove the loosened screw by pulling it upwards.
  14. Capresso Infinity Bottom Conical Burr Replacement: étape 14, image 1 de 3 Capresso Infinity Bottom Conical Burr Replacement: étape 14, image 2 de 3 Capresso Infinity Bottom Conical Burr Replacement: étape 14, image 3 de 3
    • Grip the plastic piece at the top of the conical burr and pull upwards to remove.
    • Grip the metal burr, and pull upwards to slide it off the plastic base.
  15. Capresso Infinity Bottom Conical Burr Replacement, Spring and Bearing Positions: étape 15, image 1 de 1
    • This is the correct position of bearings and springs when the screw and bottom burr are removed.
8 autres ont terminé cette réparation.
Nina Mackin
Membre depuis le 10/09/18
555 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team S1-G1, Leahy Fall 2018 Membre de l'équipe USF Tampa, Team S1-G1, Leahy Fall 2018
USFT-LEAHY-F18S1G1
4 membres
5 tutoriels rédigés
12 commentaires de tutoriel
Step 5. In my machine there are 5 taps im bottom that has to be released with a screwdriver, before outer cap can be liftet up.
Step 9, It is essential to mark the location of black plastic ring in regards to white plastic part with holes AND in regards to ex. white square plastic part before removing part. Othervise you can’t assemble or you could destroy the burrs when you adjust the grinder to very fine grinds
dorthe - Réponse
Hi is it possible to remove the top burr? If yes how?
Thanks
Raj haraniya - Réponse
Great description of how to remove the bottom burr. Would be even greater if a new burr was available, which it is not.
Craven Morehead - Réponse
burrs were found for sale on ebay. they come in a matched set. i got a set for 30 dollars. also it seems the upper burr has to be center punched out of the plastic housing it is in but i am just making an educated guess.
gt76us - Réponse
wow - Appreciate the instructions but…….screw this….$85 for a new whole new Capresso Infinity Conical Grinder….. https://www.amazon.com/gp/product/B0000A...
bradley shefmire - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 26
30 derniers jours : 111
Total : 11,742
