Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Capresso Infinity Outside Casing Replacement
Ce dont vous avez besoin
    1. Capresso Infinity Outside Casing Replacement, Metal Outside Casing: étape 1, image 1 de 2 Capresso Infinity Outside Casing Replacement, Metal Outside Casing: étape 1, image 2 de 2
      • Twist the top plastic container to the left counterclockwise.
      • Pull upwards to remove.
      Demander à FixBot
      Ajouter un commentaire
    2. Capresso Infinity Outside Casing Replacement: étape 2, image 1 de 3 Capresso Infinity Outside Casing Replacement: étape 2, image 2 de 3 Capresso Infinity Outside Casing Replacement: étape 2, image 3 de 3
      • Twist the top burr to the left counter clockwise.
      Demander à FixBot
    3. Capresso Infinity Outside Casing Replacement: étape 3, image 1 de 2 Capresso Infinity Outside Casing Replacement: étape 3, image 2 de 2
      • Flip entire device upside down.
      • Remove two rubber coverings on the back of the device.
      Demander à FixBot
    4. Capresso Infinity Outside Casing Replacement: étape 4, image 1 de 2 Capresso Infinity Outside Casing Replacement: étape 4, image 2 de 2
      • Remove four 11.59mm T10 screws.
      • The screws will have small circular washers under them. Put them aside for reassembly.
      Demander à FixBot
    5. Capresso Infinity Outside Casing Replacement: étape 5, image 1 de 3 Capresso Infinity Outside Casing Replacement: étape 5, image 2 de 3 Capresso Infinity Outside Casing Replacement: étape 5, image 3 de 3
      • Lift the metal outside casing off the black base.
      • Flip the outside casing forward so you have access to the inside of it.
      Demander à FixBot
    6. Capresso Infinity Outside Casing Replacement: étape 6, image 1 de 3 Capresso Infinity Outside Casing Replacement: étape 6, image 2 de 3 Capresso Infinity Outside Casing Replacement: étape 6, image 3 de 3
      • Remove one 11.59mm T10 screw.
      • Let the green wire fall, or place somewhere so it doesn't get in the way.
      • There will be a small metal retainer and washer, put them aside for reassembly.
      Demander à FixBot
    7. Capresso Infinity Outside Casing Replacement: étape 7, image 1 de 3 Capresso Infinity Outside Casing Replacement: étape 7, image 2 de 3 Capresso Infinity Outside Casing Replacement: étape 7, image 3 de 3
      • Remove two 11.59mm T10 screws.
      Demander à FixBot
    8. Capresso Infinity Outside Casing Replacement: étape 8, image 1 de 2 Capresso Infinity Outside Casing Replacement: étape 8, image 2 de 2
      • Remove the time/on switch by pulling upwards.
      Demander à FixBot
Nina Mackin
Membre depuis le 10/09/18
582 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team S1-G1, Leahy Fall 2018 Membre de l'équipe USF Tampa, Team S1-G1, Leahy Fall 2018
USFT-LEAHY-F18S1G1
4 membres
45 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 40
Total : 2,018
