Aller au contenu principal
Il est possible que cette traduction ne reflète pas les dernières mises à jour du tutoriel source. Aidez à mettre à jour la traduction ou bien consultez le tutoriel source.
Changement écran tactile Nintendo 3DS XL
Ce dont vous avez besoin
  1. Changement écran tactile Nintendo 3DS XL, Batterie: étape 1, image 1 de 2 Changement écran tactile Nintendo 3DS XL, Batterie: étape 1, image 2 de 2
    • Desserrez les deux vis cruciformes de 4,2 mm de long situées en haut de la coque arrière.
    • Les vis ont des rondelles de blocage qui empêchent les vis de tomber de la coque arrière. Laissez ces rondelles de blocage sur les vis ; il n'est pas nécessaire de retirer les rondelles pour ce tutoriel de réparation.
    Note: If your top or bottom screen was working before disassembly and doesn't work after reassembly, then it's likely that the connector is loose or dirty or damaged or not clipped or PLACED UPSIDE-DOWN. I had this issue with my Super3DS XL(2015) and it turns out that the reason why my top screen wasn't working after put together, was because I had the top LCD connector upside-down. After I correctly put the connector in, It worked again!
    justjustintuber - Réponse
    what type screwdriver do i use?!? its so small!!!!
    Matthew - Réponse
    I had success using a #00 Phillips head
    Jake S -
    Can't clip the front of the back cover back in
    Macro Man - Réponse
    I had trouble too, but got past it by slipping the bottom edge into the three indents first then easing the rest of the cover on!
    Issu -
    I found these were actually #00
    Demosthien - Réponse
    The screws in the 1st picture are stripped. What screwdriver head do I use?
    Adric101 - Réponse
    The official battery replacement guide by Nintendo says the screws should indeed be removed by a Phillips #00 screwdriver, so I've edited the guide to reflect that.
    They are actually JIS screws though so they could be stripped by that screwdriver
    MightyOak - Réponse
  2. Changement écran tactile Nintendo 3DS XL: étape 2, image 1 de 2 Changement écran tactile Nintendo 3DS XL: étape 2, image 2 de 2
    • Tenez l'appareil de manière à ce que la coque soit orienté vers le haut.
    • À l'aide d'un outil d'ouverture en plastique, soulevez la coque en commençant par le coin supérieur droit.
    • Tenez le bord de la coque pour vous assurer qu'il ne se remet pas en place.
    • Recherchez la petite section sous le compartiment du stylet. Retirez la coque à ce stade si elle est toujours attachée.
    • Retirez la coque de l'appareil et mettez-la de côté.
    Note that on the lower side (opposite to the hinges), there are small hooking tabs. These require you to lift the top (screw side) off towards you, then the lower area.
    Jordan Kelly - Réponse
  3. Changement écran tactile Nintendo 3DS XL: étape 3, image 1 de 3 Changement écran tactile Nintendo 3DS XL: étape 3, image 2 de 3 Changement écran tactile Nintendo 3DS XL: étape 3, image 3 de 3
    • Insérez l'outil d'ouverture en plastique dans l'ouverture située sur le côté droit de la batterie.
    • Retirez la batterie du boîtier inférieur.
    • Retirez la batterie du boîtier et mettez-la de côté.
    My 👴 grandpa was helping me 🔧 repair my 3ds xl and ⚡️electrocuted himself with the 🔋battery while we was taking it out with a 🔪 knife. 💀 Rip grandpa 😔
    Corban Bennett - Réponse
  4. Changement écran tactile Nintendo 3DS XL, Joystick: étape 4, image 1 de 2 Changement écran tactile Nintendo 3DS XL, Joystick: étape 4, image 2 de 2
    Outil utilisé dans cette étape :
    • À l'aide d'une pincette, retirez les tampons en caoutchouc situés en haut de l'appareil, de chaque côté du compartiment de la cartouche de jeu.
    I found that the rubber bumps don't move easily, you'll likely have to use a lot of upward force to move them.
    jconnell85 - Réponse
    I torn one of the bumpers because I used a needle instead.
    luxusmirajane - Réponse
    You do have a pry a bit. I tore one a little but not that big of a deal.
    Christopher - Réponse
    I think the ease of this step would be subject to the age and condition of the 3DS. Mine came out with minimal leverage using my nails.
    infmz - Réponse
    try twisting upward
    Kmi Nguyen - Réponse
    I used a super tiny metal screwdriver to push the bumper against one side and then used the screwdriver to push it up and out
    S Maduras - Réponse
    I tried tweezers but they were scraping against the plastic and I didn't want to leave any marks. Ended up using a tiny flat screwdriver to get them out like S Maduras said. Once I got them out I noticed there was a tiny bit of glue on the bottom holding them in place.
    Anth Rodi - Réponse
    My 3DS XL is so old that the rubber bumpers were very hard to remove.
    So I tried to heat the rubber bumpers a little bit with a hair dryer for 15-20 seconds, with some pauses every 5 seconds in order to avoid overheating or damaging something as a precaution.
    It worked well to remove them but the only drawback is that as my rubber bumpers already got damaged and scratched because of my previous attempts without heating first, heating it up after aggravated the scratch damages when I used tweezers.
    So I would recommend heating the rubber bumpers moderately first and be gentle when using something that could scratch or damage them.
    (Do not take my words for it, it may not work for you)
    S. Tony Ly - Réponse
    I was able to remove mine that were being very difficult with some dull tweezers. I used dull ones because I didn't want to scratch anything. First I wedged it between the plastic and the bumper, wiggled it a tiny bit, pulled it out, wedged it again in another spot and continued this until I got it out with my fingernail. Neither the bumper nor my shell were damaged.
    Brently - Réponse
  5. Changement écran tactile Nintendo 3DS XL: étape 5, image 1 de 2 Changement écran tactile Nintendo 3DS XL: étape 5, image 2 de 2
    • Retirez les six vis de 6,2 mm à l'aide d'un tournevis cruciforme #00.
    #000 ifixit philips screwdriver does not fit the 6.2mm screws. Whats the deal?
    sevenethshinobi - Réponse
    I have a 000 Phillips from tekton and it worked just fine.
    Megan -
    I stripped a good #000 screwdriver, and found that EVERY screw actually fit perfect and snug with a #00 screwdriver. Zero damage to the screws or the screwdriver with the #00.
    Vannicke Trabeitt - Réponse
    Don't buy the #000 screwdriver from this site! It's poorly made and strips the screws. I had to drill the screws out and replace them, it was very tricky and nearly broke my DS. Get a screwdriver from an electronics store.
    sharga - Réponse
    I bought and used the #00 screwdriver, and it worked perfectly for this.
    I had also bought the #000, but I never needed it during the entire operation.
    All 6 screws are exactly the same so you don't have to worry about mixing them up.
    One of the screws in my 3ds XL seems to have its '+' engraving worn off, i can't seem to unscrew it, though the other 5 unscrewed properly. What should I do?
    Potato Man - Réponse
    J000 works better here.
    Dom - Réponse
    I stripped a screw in my 3ds xl and don’t know how to get it out. Do I have to use a drill or is there another way?
    Troy Czaban - Réponse
  6. Changement écran tactile Nintendo 3DS XL: étape 6, image 1 de 1
    • Retirez la vis de 2,3 mm située au-dessus de la cartouche de jeu à l’aide d’un tournevis cruciforme #00.
    between these two steps, the bottom two screws are not mentioned. make sure to take those out too ;)
    anthony pullano - Réponse
  7. Changement écran tactile Nintendo 3DS XL: étape 7, image 1 de 3 Changement écran tactile Nintendo 3DS XL: étape 7, image 2 de 3 Changement écran tactile Nintendo 3DS XL: étape 7, image 3 de 3
    • Assurez-vous que la carte SD a été retirée. Avec un outil d’ouverture en plastique, soulevez le boîtier inférieur en commençant par le bord inférieur et en travaillant autour du périmètre.
    • Deux nappes relient le boîtier à la carte de circuit imprimé. Veillez à ne pas tirer le boîtier trop fort et déchirer les nappes.
    Make sure that you have removed your SD card, otherwise that'll keep you from completing this step.
  8. Changement écran tactile Nintendo 3DS XL: étape 8, image 1 de 3 Changement écran tactile Nintendo 3DS XL: étape 8, image 2 de 3 Changement écran tactile Nintendo 3DS XL: étape 8, image 3 de 3
    • Retirez les nappes situées sous les gâchettes gauche et droite en soulevant la base des nappes avec un outil d'ouverture en plastique.
    • Retirez complètement le boîtier inférieur du reste de l'appareil et mettez-le de côté.
    The IR board is facing the wrong way.
    Jordan - Réponse
    Thank you so much for pointing that out, it was keeping my system from starting up and I thought I blew it!
    Ryan Hescock -
    Yup, that is definitely an upside-down IR board, and will result in a silent post error. It was driving me crazy trying to figure out why the system wouldn't start up.
    alexmouravskiy -
    That's it!! Thanks so much!! I've tinkered around about one month and couldn't get this thing to work...all because I've followed the guide here and looked the picture up twice so I don't put the IR-Board in the wrong way...
    chfreydank -
    Hehe. That would explain why it was not working ;-)
    boma40 - Réponse
    Thank you guys so much! I followed everything faithfully and it was DOA on startup. (Black screens, blue light). The IR board was backwards. These pictures need to be fixed. As-is, it shows a broken 3DS.
    jtmuehlbauer - Réponse
    You should always work on the device in a 3/4 open position- this allows the ribbon cables to have slack and will less likely tear, and is the only position the hinge pin can be removed or installed as it is keyed
    Gabriel Wilkins - Réponse
  9. Changement écran tactile Nintendo 3DS XL: étape 9, image 1 de 2 Changement écran tactile Nintendo 3DS XL: étape 9, image 2 de 2
    • Positionnez l'appareil de manière à ce que la fente pour cartouche de jeu se trouve en haut.
    • Localisez le joystick sur le côté droit de l'appareil.
    • Retirez les deux vis de 7,5 mm dans les coins supérieur gauche et inférieur droit.
    This IR is bad side, diode IR must be UP
    patholog - Réponse
    Careful you don’t lose the little washer on the circle pad stem. It’s not held down by anything.
    edwardsgreg - Réponse
  10. Changement écran tactile Nintendo 3DS XL: étape 10, image 1 de 2 Changement écran tactile Nintendo 3DS XL: étape 10, image 2 de 2
    • À l'aide d'un outil d'ouverture en plastique, retirez le joystick.
    • N'utilisez pas de force excessive avec l'outil d'ouverture en plastique. Une nappe relie le joystick à la carte mère, elle restera attachée.
    • Il y a une rondelle libre située entre le joystick et son emplacement. Soyez prudent et ne perdez pas cette pièce.
    I found it easy to put my finger ontop of the board and apply a little pressure. When i popped off the board, my finger stopped it flying off.
    Chris Ramsay - Réponse
    I made a small mistake by popping the circle pad joystick and it went flying off and now im stuck trying to put it back in
    magnus munoz - Réponse
  11. Changement écran tactile Nintendo 3DS XL: étape 11, image 1 de 2 Changement écran tactile Nintendo 3DS XL: étape 11, image 2 de 2
    • À l'aide du côté plate d'une spatule (spudger), soulevez délicatement le rabat de retenue qui attache la nappe du joystick à la carte mère.
    • Retirez la nappe et le joystick.
    The 'flat head' holds it in place when down, and you can reattach your ribbon cable when it's up, it only needs to be partway in so when you close the flat head, if your joystick board can't move easily in place then you've done it right, it it's too loose, try again to work the ribbon cable under.
    The ribbon goes into the left side of the "flat head" right? Not the end that clamps down on the right? I'm having a !&&* of a time sliding the end of the ribbon into the little space between the flat head when it's up and the side of the terminal.
    Sedroc Djeddi -
    For those of you like me, who got stuck after the last step.
    To understand how to actually remove the circle pad, continue with these steps at 21.
    Changer le pad circulaire de la Nintendo 3DS
    Hope it helps those after me. I almost ripped some cabling inside thinking I had to take out the motherboard.. luckily I didn't.
    monk333y - Réponse
    Just as what monk333y said, follow the Original 3DS steps. They are identical and you don't have to remove anymore big parts. The only annoying part is taking out the circle pad.
    I broke the retaining clip. It is not very strong and I used a bit too much force i think in opening the clip or pushing it back down. Thinking of using hot glue or something else to keep the circle pad ribbon in place.
    Lawrence - Réponse
    Did the hot glue work? I did the exact same thing now im not sure what to do…
    Matthew Johnson -
    How do you re attach the ribbons? do the just snap right into the motherboard?
    petraogan - Réponse
    thank you monk333y, the author of this guide needs to correct a couple of things and how hard would it be for her to add steps 21 onward from the other guide?
    S Maduras - Réponse
    step 11, if you're just replacing the button, you don't need to disconnect the circle pad ribbon from the motherboard.
    S Maduras - Réponse
    During re-assemblhy, note that the peg between the joystick mechanism and the circle pad is rectangular, and must fit into the matching rectangular socket on the circle pad.
    Dan - Réponse
    When testing the touchscreen, make sure you install the analog. Otherwise, the screen will act erratic. Thought I broke a brand new part. Just a heads up!
    Hassan Sinanan - Réponse
    The entire top part of my circle pad had broken off, so I had no problem getting the old one out. I actually had more trouble getting the ribbon cable back into the clip, and the new circle pad attached to the stick, than any other part.
    That said, this was way, way easier than I expected it to be.
    Emtu - Réponse
  12. Changement écran tactile Nintendo 3DS XL, Circuit IR: étape 12, image 1 de 2 Changement écran tactile Nintendo 3DS XL, Circuit IR: étape 12, image 2 de 2
    • Positionnez l'appareil de manière à ce que la fente pour cartouche de jeu soit située en haut.
    • Localisez la carte IR située sur le côté supérieur droit de la carte mère.
    • La carte IR est installée à l'envers sur ces photos par erreur. En l'installant de cette façon, votre DS ne démarrera pas. Notez l'orientation de votre carte infrarouge avant de la retirer et réinstallez-la de la même manière.
    • Retirez la carte IR avec un outil d'ouverture en plastique en insérant l'outil sous la carte IR et en soulevant doucement.
    The IR board appears to be upside down in this photo.
    Eric - Réponse
    One assumes they forgot to take the photo before removal and quickly put it back on upside down (accidentally) for the purposes of taking the photo.
    Retro Gaming Repair -
    Removing the IR board is actually a completely unnecessary step. It's absolutely fine to leave the IR board attached to the motherboard, it's then one less loose piece to go missing ;)
    Retro Gaming Repair - Réponse
    The reason they remove these "easily loosable" pieces is because there's an order to put the board back together or the 3DS won't turn on. This is for replacing the motherboard, which most of the time you will buy and it won't come with the microphone, volume or IR board. Use your head kiddo. If it's so easy to loose these pieces, you should keep better track of them. We might as well just not take out any screws as well because those are very easy to loose
    Miles Holiman -
    You should add this note to the other uses of this picture; I accidentally knocked that chip off and reinstalled it upside down. I was referencing the photos for replacing the joystick.
    Infernal Dalek - Réponse
    You skipped removing the microphopne.
    Mykaila Brown - Réponse
    In my 3DXL, there was no IR board: the parts were installed directly on the motherboard.
    Dan - Réponse
    I agree my 3dxl the IR board is also part of the motherboard and doesnt come off.
    Anthony siracuse - Réponse
  13. Changement écran tactile Nintendo 3DS XL, Carte mère: étape 13, image 1 de 2 Changement écran tactile Nintendo 3DS XL, Carte mère: étape 13, image 2 de 2
    • À l'aide d'un outil d'ouverture en plastique, soulevez la carte Wi-Fi.
    • La carte Wi-Fi sera toujours reliée par un fil et il n'est pas nécessaire de la retirer complètement pour cette étape. Placez-la simplement à l'écart pour cette étape.
    Component on bottom left was taken off, but not mentioned. Not sure what it does it does, and I'm assuming it's unimportant, but I just wanted to note.
    Jordan - Réponse
    The thing on the bottom left in the little black rubber cover is the mic!
    Maxwell Alexander -
    Why not just seperate the wifi board from the antenna now while in your hands? You're going to do it later anyway...
  14. Changement écran tactile Nintendo 3DS XL: étape 14, image 1 de 2 Changement écran tactile Nintendo 3DS XL: étape 14, image 2 de 2
    • Localisez le commutateur de volume sur le côté droit de la carte mère à côté du joystick du pad circulaire.
    • À l'aide d'une pincette, retirez délicatement la carte de volume du boîtier. Elle restera toujours attachée à la carte mère par une nappe.
    As previously commented, in this step the microphone (lower left corner) was removed.
    This is done by opening the grey flap, removing the ribbon from the motherboard and then either remove it or just let it sit in it’s place.
    In my experience the motherboard will go around it easily.
    Stefan Nicodem - Réponse
  15. Changement écran tactile Nintendo 3DS XL: étape 15, image 1 de 1
    • À l'aide du côté plat d'une spatule (spudger), soulevez délicatement le rabat qui attache la nappe de la carte de volume à la carte mère.
    • Retirez la carte de volume et mettez-la de côté.
    This step proved to be unnecessary. It's perfectly fine to leave it attached, and again it's one less small fiddly piece to go missing.
    What if I pushed flap too hard and detached and cant find. Now I unable to secure in. Is there a part for this?
    Crystal Ramirez - Réponse
    Its is the small grey flap that holds in the ribbon.
  16. Changement écran tactile Nintendo 3DS XL: étape 16, image 1 de 2 Changement écran tactile Nintendo 3DS XL: étape 16, image 2 de 2
    • Retirez les morceaux de plastique noir des coins inférieurs gauche et droit avec vos doigts ou une pincette.
    • Vous pouvez également retirer ces pièces facilement en soulevant délicatement la 3DS et en la tenant à l'envers. Ils tombent normalement tout de suite, mais ne les perdez pas !
    Does anything happen if you lose them or not, that last part made me a little worried?
    Ptheassassina - - Réponse
    You won't be able to attach a lanyard to the console anymore, and the uncovered holes will provide egress to the inside of the console for dust and debris and whatnot, but that's about it
    Jodjuya -
  17. Changement écran tactile Nintendo 3DS XL: étape 17, image 1 de 3 Changement écran tactile Nintendo 3DS XL: étape 17, image 2 de 3 Changement écran tactile Nintendo 3DS XL: étape 17, image 3 de 3
    • À l'aide du côté plat d'une spatule, soulevez délicatement le rabat qui attache les deux nappes plus petites à la carte mère.
    • Ces rabats sont situés en haut à droite et en bas à droite de la carte mère.
    • Retirez les nappes du rabat.
    For the first picture on step 17, (the one at the top of the board) what does that cable connect to? My clip broke.
    Bradly - Réponse
    MMM as far as I can tell it looks like it's for the touch screen as it plugs into p13 and is the same plug type as p10, p12 and p17 and a couple others. Could be wrong though :)
    Connor -
  18. Changement écran tactile Nintendo 3DS XL: étape 18, image 1 de 3 Changement écran tactile Nintendo 3DS XL: étape 18, image 2 de 3 Changement écran tactile Nintendo 3DS XL: étape 18, image 3 de 3
    • À l'aide du côté plat d'une spatule, soulevez délicatement les rabats qui fixent les nappes plus larges à la carte mère.
    • Assurez-vous de soulever les rabats du côté blanc pour les nappes plus larges.
    • Retirez les nappes des rabats ouverts.
    Note: the top right wider ribbon is for the camera, the thinner ribbon in the top right is for the speakers and the bottom ribbon is to the upper lcd. You will want to ensure you stack the ribbons appropriately when putting the system back together.
    Elaine - Réponse
    Had some trouble with this: Not exactly sure why, but when after successfully replacing the screen and beginning to resemble, while reinserting the wide ribbon for the lower LCD (p8) it seems that the white locking clip unhinged itself from the connector, and bent some of the pins. The ribbon now won't fully insert.. Can't figure out if I've somehow completely ruined my 3ds. Mostly concerned about my save data that's not on my sdcard.
    kbbauer - Réponse
  19. Changement écran tactile Nintendo 3DS XL: étape 19, image 1 de 2 Changement écran tactile Nintendo 3DS XL: étape 19, image 2 de 2
    • À l'aide du côté plat de la spatule, soulevez délicatement le rabat qui attache la nappe à la carte mère.
    • Pour ce rabat, soulevez du côté noir.
    • Retirez la nappe du rabat.
    • Remontage : Ce large ruban est celui avec la BANDE NOIRE et se place sur la face supérieure (visible) de la carte mère lors du remontage.
  20. Changement écran tactile Nintendo 3DS XL: étape 20, image 1 de 2 Changement écran tactile Nintendo 3DS XL: étape 20, image 2 de 2
    • Retirez les dix vis de 3 mm situées autour de la face de la carte mère.
    It’s not a *!&*^#% 5.5mm, it’s 0.05mm probably. I ended up using wrong screws and punctured the housing. So wrong!
    장한솔 - Réponse
    I think those 5,5 mm mean the length (!) of the screws. The heads are normal little Philipps, perhaps #00 or #000.
    VauWeh - Réponse
    I took a micrometer to these screws, they are not 5.5 mm long.
    Evan J Garner - Réponse
    These screws are 3.0mm long.
    Marques Jones - Réponse
    Fair warning- the xl shown here doesn't seem to have a microphone, but there is probably one on your board. in the bottom left, lift up the flap that attaches the ribbon to the motherboard and remove it. gently pull out the microphone and set aside. I almost tore out my mic while doing this the first time.
    TyphoonTiak - Réponse
  21. Changement écran tactile Nintendo 3DS XL: étape 21, image 1 de 2 Changement écran tactile Nintendo 3DS XL: étape 21, image 2 de 2
    • La carte mère sera toujours attachée dans le coin supérieur droit, ne la détachez donc pas complètement à ce stade.
    • Soulevez délicatement la carte vers le haut juste assez pour dégager les deux supports en plastique situés près des coins supérieurs de la fente de la cartouche.
    • Pivotez délicatement la carte mère sur le côté supérieur.
    Laying it down like this puts too much stress on the ribbon cable. I find it better to release the connector while the board is tilted at a 90 degree angle to the body of the 3DS. Less chance of damage to the top screen cable that way.
    Add to this step, during reassembly: make sure the volume slider and wi-fi sliders are lined up correctly with their outer switches.
    Scott Barrow - Réponse
  22. Changement écran tactile Nintendo 3DS XL: étape 22, image 1 de 2 Changement écran tactile Nintendo 3DS XL: étape 22, image 2 de 2
    • À l'aide du côté plat de la spatule, soulevez délicatement le rabat qui attache la nappe la plus large située en haut à droite à la carte mère.
    • Veillez à soulever le rabat du côté blanc.
    • Retirez la nappe du rabat ouvert.
    • Mettez la carte mère de côté.
    So I tore this wire is this the visual or something?? Please help
    linkon king - Réponse
    I tore this wire too. Am I able to buy it individually?
    dobe mon - Réponse
    How do you get this cable back in? It is way too short...
    Luke Miller - Réponse
    Tweezers, steady hand, and a little luck.
    Marcus DeCamp - Réponse
    So, before step 23 do you put the bottom half of the 3ds xl back together?
    Poké Pi. - Réponse
    When fixing, I can't put the 2 wires in the connector. HELP!
    Owen Burch - Réponse
    are there issues with compatibility between motherboards? one works perfectly and the other powers on then off
    xdboost - Réponse
    Don't unplug this cable. Just leave the motherboard flat and don't move it while replacing the face button(s). This thing is way too hard to get back in.
    Engiturtle - Réponse
    It's hard to put it back but it's doable if you spend a lot of time, it took me around an hour and a half, also make sure you put it well because the first time, it was not fully inserted and the screen was flickering with gray lines so after I reinserted it worked fine.
    Levan Kakashvili - Réponse
  23. Changement écran tactile Nintendo 3DS XL, Ecran tactile: étape 23, image 1 de 2 Changement écran tactile Nintendo 3DS XL, Ecran tactile: étape 23, image 2 de 2
    • Ouvrez la charnière de l'appareil.
    • Appuyez doucement vers le haut sur l'écran tactile jusqu'à ce qu'il se sépare du boîtier.
    Hi everybody,
    Just to comment that they have some adhesive double tape between the LCD/touchscreen and the case. So be careful too.
    Chi Thuan Phan - Réponse
    I found that using a spudger to wedge it worked for me.
    super bien expliqué bravo
    zazout - Réponse
Pour remonter votre appareil, suivez ces instructions dans l'ordre inverse.
65 autres ont terminé cette réparation.
Merci à ces traducteurs :
en fr
44%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
Charlene Donlon
Membre depuis le 04/08/14
10 610 Réputation
8 tutoriels rédigés
Équipe
Cal Poly, Team 9-13, Regan Spring 2014 Membre de l'équipe Cal Poly, Team 9-13, Regan Spring 2014
CPSU-REGAN-S14S9G13
5 membres
44 tutoriels rédigés
24 commentaires
what if you need to replace the screen on the top housing? what is it called.
kerriereed - Réponse
Is the bottom LCD screen of the Nintendo 3ds xl, the same as the one in the NEW Nintendo 3ds xl?
Looking for what part to buy.
markknobel - Réponse
Bit old, but did you figure out the answer which to buy?
White -
Very detailed and easy to use step by step thanks. However, after reassembly after I switch the power button on it starts and then a flash and it trips out? Obviously a fault somewhere but not sure where to start.? Any thoughts appreciated.
Pete Mason - Réponse
That's to do with a part this tutorial skips: you need to put some insulation between the new screen and the motherboard. That's what that orange film is on the back of the screen in the photos. When replacing, you can easily (carefully) remove that film and stick it onto the back of the new screen, no problem. Or you can put some other sort of adhesive to create some insulation between the screen and motherboard. Hope this helps.
Albert Wiltfong -
where can i get replacement adhesive tape? my touchscreen is fine, but the system was previously owned by a child so the adhesive lining is filled with food bits and whatnot, tried google but can't find anything so far.
Elizabeth Morse - Réponse
Thank you so much for this tutorial! I was able to fix my DS thanks to this after I dropped it and the touchscreen became weird. The problem I was having was a black touch screen with a glitched line across it that still responded to touch. I could tap on things on the touchscreen and the top screen would respond, but there were no images on the touchscreen. This was exactly what I needed and I recommend it to anyone with similar problems.
Riley McIntosh - Réponse
So I was trying to fix my 3ds xl (2015) the other day and the problem was when I would flip my 3ds open it would make a pop sound and shut off. I went in following instructions on how to assemble it and all that. Afterward I didn't fix it so I just decided I'll save for a new one. In doing all this I created another problem. My bottom LCD displays but it will not respond to touch. Does this mean I need a new bottom LCD? I have a lot of games and data I don't want to lose just because my bottom screen won't respond. In order to keep it all I need to do a system transfer which I can only do in system settings which requires touch to navigate. Can anyone help?
Spencer - Réponse
It's the older 3ds xl model not the New Nintendo 3ds
Spencer -
The re-attachment of that first cable was a challenge, trying to wrestle the chassis, motherboard, and ribbon cable. I've written a short guide that makes it much easier, accessible here:
Re-installing the motherboard of the 3DS XL
Dan - Réponse
I broke the plastic touchscreen on the bottom screen. (Not the LCD) So basically the plastic part has a dent in it, and it’s always tapping in one place. Now I would’ve gotten it fixed by now, but the problem is I have the new 2015 3ds xl, so I’m not 100% sure if this guide will work. If someone could confirm for me, that would be very appreciated! :)
Zachary Watson - Réponse
how do take the hinge off
Hammer Gaming - Réponse
This is not helpful I need one that is kid friendly usually I can fix anything as a 12yr old girl but this was confusing.
Katherine Jhonson - Réponse
I did a full housing swap and only the touch screen doesn’t respond. The bottom screen still shows an image though. Should I just replace the digitizer?
mrjennyl - Réponse
Thanks a lot. This was a really detailed guide which got my 3ds working in no time at all. Reassembling the ribbon cables is probably the hardest thing to do on this small project.
Tommie Aldridge - Réponse
I’m following the instructions, but I broke the ribbon cable for the volume board. I guess I won’t be using this 3DS anymore.
Doggo Boi - Réponse
Thank you very much, my daughters 3DS XL is working again!
During the reassembly the white locker of the ribbon cable from step 18/pic. 2 jumped out. This was nearly the death of the Nintendo… To get it back on the two rows of the maybe 100 pins I needed 3 trys of around 15 min. each before stopping the repair for this day and beeing very frustrated. This thing was way too small for human Hands ;-)
The 4th try was successfull, but the locker lost the two guiding side-pieces. After closing it, I taped it down and it’s working!
So be carefull with this while reassembling :-)
saal - Réponse
Does the digitizer need replaced too?
James McCurry - Réponse
Not always, I've found that if you don't damage the ribbon cable then you can reuse the digitizer.
Dakota Smith -
Extremely confused, how does the mid-frame come into play here? Yes it houses the digitizer but how do you join that with the LCD screen? The actually replacement was poorly detailed here as well. This seems to be the only real guide for the bottom screen, an actual video needs to be made, one that notes the differences of the LCD and digitizer.
Dhanushka Jayasinghe - Réponse
so i tried to fix my touch screen because it as off, ant when i put it back together, the touch screen turns on, but now it dosent even register that i tap it at all. is htere some thing i did wrong?
zach Snider - Réponse
Thanks for putting this together. I had been a while since the last time I replaced a 3DS lower LCD and definitely needed a refresher. Appreciate the effort that went in to this. Many thanks!
Matthew D. H. - Réponse
the link for the bottom touchscreen lcd on this guide is different from the one that you need to install, when looking for screens for old/o3ds please make sure to get the screen with 1 wire on the top side, 2 on the bottom, and a golden plate, not silver. I've had to return several parts due to this error and me not noticing right away
Plasmaneer - Réponse
When doing step 18, the white part of the wide ribbon attachment came off. Does it reconnect or will it need to be soldered and replaced?
Andrew Thomas - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 24
7 derniers jours : 189
30 derniers jours : 822
Total : 100,893
