Craig CMP801 LCD Screen Replacement
Introduction
Passez à l'étape 1In order to replace the LCD screen you must remove all the other parts, starting from the back panel.
Ce dont vous avez besoin
Locate the opening line between the cover and the device. Then locate the groove near the charging port.
After taking out the back cover, locate the black flap.
Open the black flap with the plastic opening tools.
Outil utilisé dans cette étape :Tweezers$3.99
Once the tab is released, use the angled tweezers to take out the tab.
Locate the white plug next to the battery.
Use your fingers to pull off white plug that connected to the battery.
