Aller au contenu principal
Creative Zen Vision M Battery  Replacement
Kirstie G
Kirstie G et 6 autres contributeurs
Dernière mise à jour le January 21, 2019
10 minutes
Modérée
Outils incorrects
This guide will demonstrate how to replace a faulty battery. Tools needed are: 1mm Phillips head screwdriver and a blunt flat edged tool (a plastic card will work). Keep in mind that since the Creative Zen Vision M was released in 2005, and now discontinued, you may have difficulty purchasing a new battery.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Creative Zen Vision M Battery  Replacement, Opening the top: étape 1, image 1 de 2 Creative Zen Vision M Battery  Replacement, Opening the top: étape 1, image 2 de 2
    • Pop off the top plastic on the device with a flat tool like a flathead screwdriver.
    • Unscrew and remove the two exposed Phillips head screws
    Caution! Some models have two screws at the dock connector end also. Don’t ask me how I know…
    Des Sheppard - Réponse
  2. Creative Zen Vision M Battery  Replacement, Opening the device: étape 2, image 1 de 2 Creative Zen Vision M Battery  Replacement, Opening the device: étape 2, image 2 de 2
    • Work your way around the recess of the device with a flat tool like a flathead screwdriver.
    • Don't try attempt to open it from the recess between the buttons and the device.
    It should mention that you need to remove the bezel from the charging port and also remove the 2 screws located behind it to open the device without breaking the screw mounts.
    ConorY95 - Réponse
    I concur, you need to remove the plastic bezel from the charging port in order to gain access to these 2 screws (they are shorter than those from the upper part).
    Triet - Réponse
  3. Creative Zen Vision M Battery  Replacement, Detaching the wires from the screen: étape 3, image 1 de 3 Creative Zen Vision M Battery  Replacement, Detaching the wires from the screen: étape 3, image 2 de 3 Creative Zen Vision M Battery  Replacement, Detaching the wires from the screen: étape 3, image 3 de 3
    • To detach wires from the screen, gently tug on the wires connected to the battery. They are located on the bottom half of the screen.
  4. Creative Zen Vision M Battery  Replacement, Releasing the battery: étape 4, image 1 de 1
    • To begin removing the battery, move the wires out from under the black foam at the bottom of the device
  5. Creative Zen Vision M Battery  Replacement, Removing the battery: étape 5, image 1 de 2 Creative Zen Vision M Battery  Replacement, Removing the battery: étape 5, image 2 de 2
    • Use a plastic opening tool or nylon spudger to lift up the battery.
    • Battery may be glued on the edges.
    • The metal spudger is great for serious prying power, but the regular black nylon spudger should be used whenever possible, especially around batteries.
6 autres ont terminé cette réparation.
Kirstie G
Membre depuis le 10/12/16
479 Réputation
4 tutoriels rédigés
Équipe
Texas Tech, Team 12-1, Bennett Fall 2016 Membre de l'équipe Texas Tech, Team 12-1, Bennett Fall 2016
TTU-BENNETT-F16S12G1
4 membres
4 tutoriels rédigés
3 commentaires de tutoriel
Step 1 does not mention that the bottom cover needs to also be removed to access two more screws. Make note of the screw lengths and where they come from.. Two are shorter.
Bob Terwilliger - Réponse
Seconding this, if you try to separate the top and bottom covers before unscrewing the two screws to the sides of the charging/data port you may damage your device irreparably. In my case I had already watched a guide online and I did not damage mine, but after so many years the plastic has degraded and it's very easy to see how you could do some serious damage if you're not careful.
valpampa -
Does anyone know, what do you do if the existing battery goes completely flat, and the unit will not charge. I believe the battery needs replacing. Are these batteries available, and if they do, what is the shelf life of a new battery?
Carl MacCulloch - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 6
7 derniers jours : 20
30 derniers jours : 90
Total : 5,921
