Aller au contenu principal
Cuisinart DFP-14BCN Switch Replacement
Sonya Dick
Sonya Dick et 3 autres contributeurs
Dernière mise à jour le December 22, 2016
20 - 25 minutes
Modérée
Tutoriel étudiant vedette
A broken switch means electricity is not flowing through your device. Removing and replacing this component requires soldering. Check out this soldering guide for instructions.
Ce dont vous avez besoin
iFixit touche une commission lorsque vous achetez par l'intermédiaire de ces liens.
  1. Cuisinart DFP-14BCN Switch Replacement, Bowl: étape 1, image 1 de 3 Cuisinart DFP-14BCN Switch Replacement, Bowl: étape 1, image 2 de 3 Cuisinart DFP-14BCN Switch Replacement, Bowl: étape 1, image 3 de 3
    • Unplug your food processor before starting any disassembly.
    • Remove the small pusher by rotating it clockwise and lifting up.
  2. Cuisinart DFP-14BCN Switch Replacement: étape 2, image 1 de 1
    • Remove the large pusher by grabbing its sides and pulling up.
    • There may be a clicking sound from the safety feature being disengaged in this step.
  3. Cuisinart DFP-14BCN Switch Replacement: étape 3, image 1 de 3 Cuisinart DFP-14BCN Switch Replacement: étape 3, image 2 de 3 Cuisinart DFP-14BCN Switch Replacement: étape 3, image 3 de 3
    • Remove the lid from the bowl by turning it clockwise and lifting.
  4. Cuisinart DFP-14BCN Switch Replacement: étape 4, image 1 de 1
    • Take out the blades by grabbing the plastic center piece and lifting up.
    • Avoid contact with blades as they are extremely sharp.
  5. Cuisinart DFP-14BCN Switch Replacement: étape 5, image 1 de 3 Cuisinart DFP-14BCN Switch Replacement: étape 5, image 2 de 3 Cuisinart DFP-14BCN Switch Replacement: étape 5, image 3 de 3
    • Position the handle of the bowl so that it is on your left.
    • Grab the handle and push clockwise. Lift up the bowl to remove it.
  6. Cuisinart DFP-14BCN Switch Replacement, Back Casing: étape 6, image 1 de 2 Cuisinart DFP-14BCN Switch Replacement, Back Casing: étape 6, image 2 de 2
    • Turn the food processor's base upside down by lifting it up and turning it over.
    • Position the base so that the on and pulse buttons are facing you.
    • Place the base on top of the food processor's bowl to keep the base from wobbling while you work on it.
  7. Cuisinart DFP-14BCN Switch Replacement: étape 7, image 1 de 2 Cuisinart DFP-14BCN Switch Replacement: étape 7, image 2 de 2
    • Remove the two 13.0mm screws that hold down the casing with a Phillips #2 screwdriver.
  8. Cuisinart DFP-14BCN Switch Replacement: étape 8, image 1 de 3 Cuisinart DFP-14BCN Switch Replacement: étape 8, image 2 de 3 Cuisinart DFP-14BCN Switch Replacement: étape 8, image 3 de 3
    • Lift up the front left and the back right rubber feet by pulling back the rubber with your fingers.
    • Remove the 13.0mm screw under each rubber foot with a Phillips #2 screwdriver.
  9. Cuisinart DFP-14BCN Switch Replacement: étape 9, image 1 de 2 Cuisinart DFP-14BCN Switch Replacement: étape 9, image 2 de 2
    • Lift off the back casing by raising it upward.
  10. Cuisinart DFP-14BCN Switch Replacement, Buttons: étape 10, image 1 de 3 Cuisinart DFP-14BCN Switch Replacement, Buttons: étape 10, image 2 de 3 Cuisinart DFP-14BCN Switch Replacement, Buttons: étape 10, image 3 de 3
    • Remove the two 13.0mm screws that are holding down the button assembly using the Phillips #2 screwdriver.
  11. Cuisinart DFP-14BCN Switch Replacement: étape 11, image 1 de 2 Cuisinart DFP-14BCN Switch Replacement: étape 11, image 2 de 2
    • Lift out the button assembly by pulling up.
  12. Cuisinart DFP-14BCN Switch Replacement: étape 12, image 1 de 1
    • Remove the two 5.5mm nuts with a 5.5mm nut driver.
  13. Cuisinart DFP-14BCN Switch Replacement: étape 13, image 1 de 3 Cuisinart DFP-14BCN Switch Replacement: étape 13, image 2 de 3 Cuisinart DFP-14BCN Switch Replacement: étape 13, image 3 de 3
    • Remove the two 13.0mm screws that hold the switch to the button assembly with a Phillips #2 screwdriver.
    • The screws have glue in their threads, so this step might require a little extra force.
    • Slide off the switch and yellow plastic to remove the button assembly.
  14. Cuisinart DFP-14BCN Switch Replacement, Switch: étape 14, image 1 de 2 Cuisinart DFP-14BCN Switch Replacement, Switch: étape 14, image 2 de 2
    • Desolder the white, black and red connections from the switch by using a soldering iron.
    • Refer to the soldering guide for extra help.
    • For reassembly, the new switch's connections will have to be soldered on.
Sonya Dick
Membre depuis le 10/05/16
352 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 10-3, Livingston Fall 2016 Membre de l'équipe Cal Poly, Team 10-3, Livingston Fall 2016
CPSU-LIVINGSTON-F16S10G3
3 membres
7 tutoriels rédigés
Un commentaire
You had me until the desoldering, maybe I’m just a wimp! Thanks anyway … good description!
dmdudek - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 37
Total : 1,616
