Aller au contenu principal
DJI Phantom 2 Vision Plus GPS Signal Improvement Technique
Sam Goldheart
Sam Goldheart
Dernière mise à jour le February 25, 2015
Aucune estimation
Modérée
Follow this video guide to decrease interference from the Wifi module and increase GPS signal strength.
The guide instructions are written, and the only audio is music, and will not be suitable for the visually impaired. You can follow our case top shell guide to remove the cover, and watch the video to learn how to move the GPS cable and add shielding.
Ce dont vous avez besoin
Outils
Afficher plus…
Vidéo d'introduction
  1. DJI Phantom 2 Vision Plus GPS Signal Improvement Technique, Case Top Shell: étape 1, image 1 de 2 DJI Phantom 2 Vision Plus GPS Signal Improvement Technique, Case Top Shell: étape 1, image 2 de 2
    • Remove the following screws from the underside of the Phantom:
    • Twelve 2.0 mm hex bolts
    • Four Phillips #00 screws
  2. DJI Phantom 2 Vision Plus GPS Signal Improvement Technique: étape 2, image 1 de 2 DJI Phantom 2 Vision Plus GPS Signal Improvement Technique: étape 2, image 2 de 2
    • Gently lift up the top shell case.
    • Do not attempt to fully remove the top shell. The GPS cable is still attached to the mainboard, avoid lifting the case too high or you may damage this connection.
  3. DJI Phantom 2 Vision Plus GPS Signal Improvement Technique, Unplug GPS connector and remove case: étape 3, image 1 de 3 DJI Phantom 2 Vision Plus GPS Signal Improvement Technique, Unplug GPS connector and remove case: étape 3, image 2 de 3 DJI Phantom 2 Vision Plus GPS Signal Improvement Technique, Unplug GPS connector and remove case: étape 3, image 3 de 3
    • The GPS cable molex connector is located on the backside of the mainboard, near the battery opening.
    • Pull the GPS connector straight up out of its socket.
    • Lift the top shell case up and remove it from the body of the Phantom.
4 autres ont terminé cette réparation.
Sam Goldheart
Membre depuis le 10/18/12
471 983 Réputation
538 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
121 membres
19 715 tutoriels rédigés
3 commentaires de tutoriel
hello do you still help with phantom drones
George Aguirre - Réponse
do you still help with drones/
Isn't it better to connect the aluminium foil to the GPS GND for better isolation?
Bruno Duarte - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 5
30 derniers jours : 12
Total : 4,661
