Aller au contenu principal
DJI Phantom 3 Standard Remote Controller Antenna Replacement
Makayla Williams
Makayla Williams et 3 autres contributeurs
Dernière mise à jour le January 3, 2025
5 - 10 minutes
Facile
This guide will be used to open the DJI Phantom 3 Standard Remote Controller to access and replace the antenna. Antennas are a crucial controller component because they allow for communication between the controller and the drone. An antenna replacement can improve the connection between your controller and the drone. Some antennas provide a larger controller range compared to the stock antenna.
Ce dont vous avez besoin
Outils
  • Spudger
    Spudger
  1. DJI Phantom 3 Standard Remote Controller Antenna Replacement, Antenna: étape 1, image 1 de 2 DJI Phantom 3 Standard Remote Controller Antenna Replacement, Antenna: étape 1, image 2 de 2
    • Position the controller so the back is facing up and the joysticks are resting on the table.
    • Remove the four 11 mm screws that secure the back plate using a JIS #0 screwdriver.
    • Remove the back plate, being mindful of the wires still connected to the device.
  2. DJI Phantom 3 Standard Remote Controller Antenna Replacement: étape 2, image 1 de 2 DJI Phantom 3 Standard Remote Controller Antenna Replacement: étape 2, image 2 de 2
    • Use a spudger to pry the gray antenna wire from the glue.
    • There is a small metal piece latched in and should be removed from its place as well.
    • While a plastic spudger can be used, the attachment is secure. A metal spudger may produce better results.
  3. DJI Phantom 3 Standard Remote Controller Antenna Replacement: étape 3, image 1 de 1
    • Push the wire up to the antenna.
  4. DJI Phantom 3 Standard Remote Controller Antenna Replacement: étape 4, image 1 de 1
    • Squeeze and twist the outer antenna attachment to unlatch it from its place.
    • Remove the antenna.
Makayla Williams
Membre depuis le 09/04/24
209 Réputation
1 tutoriel rédigé
Équipe
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 5
30 derniers jours : 17
Total : 148
