Aller au contenu principal
DOSS SoundBox Speaker Replacement
Brendan Harkreader
Brendan Harkreader et 8 autres contributeurs
Dernière mise à jour le January 5, 2024
25 minutes
Modérée
In the case of a faulty speaker, use this guide to remove the speaker on the DOSS Soundbox for replacement.
Removing the speaker properly allows you to be able to install a new speaker to improve the quality of the speaker for better listening.
For this project you will need a Soldering Iron and knowledge on how to safely use this tool. Soldering Irons can be very hot so its important to use this took properly and take proper measures to protect yourself from the heat it produces.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. DOSS SoundBox Speaker Replacement, Speaker: étape 1, image 1 de 2 DOSS SoundBox Speaker Replacement, Speaker: étape 1, image 2 de 2
    • Use the JIS #00 screwdriver to remove the 3/32" screws that secure the speaker to the body.
    • Remove the smaller 3/32" screws that secure the left side of the speaker with a JIS #1 screwdriver.
    • The smaller screws are still the same length, but they have smaller screw heads. You can use the same screwdriver for both.
    • Using a Magnetic Mat throughout this process will help prevent losing screws.
  2. DOSS SoundBox Speaker Replacement: étape 2, image 1 de 2 DOSS SoundBox Speaker Replacement: étape 2, image 2 de 2
    • Use the Plastic Opening Tool to gently lift the speaker enough to see the connected wires.
  3. DOSS SoundBox Speaker Replacement: étape 3, image 1 de 2 DOSS SoundBox Speaker Replacement: étape 3, image 2 de 2
    • Use a soldering iron to de-solder the two speaker wires from the speaker itself.
    • The speakers are ready to be removed and replaced.
    • Ensure that the device is turned off when handling bare wire.
    • Soldering iron is very hot.
    Try to not melt your speaker with the shaft of the soldering iron like the person in the picture is doing…ouch!
    Thousand Sunny - Réponse
To reassemble your device, follow instructions in reverse order.
2 autres ont terminé cette réparation.
Brendan Harkreader
Membre depuis le 09/27/18
538 Réputation
3 tutoriels rédigés
1 commentaire de tutoriel
The instructions say: "The speakers are ready to be removed and replaced." But nowhere in this article am I told where to get replacement speakers. Am I just on my own for that? This website has always been so helpful in providing links for such things. :(
Janie Thurman - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 16
Total : 2,980
