Aller au contenu principal
DROCON Ninja Motor Replacement
Destinee Easterly
Destinee Easterly et 5 autres contributeurs
Dernière mise à jour le May 27, 2020
30 - 45 minutes
Modérée
This guide is a replacement guide for the motors on the DROCON Ninja DC-014 drone.  The motors are a critical part of the device that power the propellers. If the drone isn’t flying straight or won’t take off the motors may need to be replaced. To determine if the motors need to be replaced check out the troubleshooting guide linked here.  A Phillips 00 screwdriver, pliers, and an opening tool are required for this guide.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. DROCON Ninja Motor Replacement, Battery: étape 1, image 1 de 3 DROCON Ninja Motor Replacement, Battery: étape 1, image 2 de 3 DROCON Ninja Motor Replacement, Battery: étape 1, image 3 de 3
    • Make sure the drone is powered off before beginning the battery replacement.
    • To turn the drone off, press and hold the black button on the top of the drone until all lights are off.
    • Firmly grasp the battery tab between your thumb and index finger.
    • Pull the battery away from the drone's body
  2. DROCON Ninja Motor Replacement, Casing: étape 2, image 1 de 3 DROCON Ninja Motor Replacement, Casing: étape 2, image 2 de 3 DROCON Ninja Motor Replacement, Casing: étape 2, image 3 de 3
    • Using a Phillips #00 Screwdriver remove the eight 4mm screws on the bottom of the drone.
  3. DROCON Ninja Motor Replacement: étape 3, image 1 de 2 DROCON Ninja Motor Replacement: étape 3, image 2 de 2
    • Gently pull white casing away from the black bottom casing
  4. DROCON Ninja Motor Replacement: étape 4, image 1 de 3 DROCON Ninja Motor Replacement: étape 4, image 2 de 3 DROCON Ninja Motor Replacement: étape 4, image 3 de 3
    • Insert the opening tool under one of the black plastic connector slots that connects the circuit-board to the casing.
    • Gently pull the opening tool toward you to disconnect the circuit-board from the plastic casing.
  5. DROCON Ninja Motor Replacement, Motor: étape 5, image 1 de 2 DROCON Ninja Motor Replacement, Motor: étape 5, image 2 de 2
    • Firmly grasp the blade guard from the bottom of the drone
    • Pull the blade guard straight down away from motor.
  6. DROCON Ninja Motor Replacement: étape 6, image 1 de 3 DROCON Ninja Motor Replacement: étape 6, image 2 de 3 DROCON Ninja Motor Replacement: étape 6, image 3 de 3
    • Grasp the center of the propeller that needs to be replaced.
    • Pull the propeller directly up and away from the motor.
  7. DROCON Ninja Motor Replacement: étape 7, image 1 de 3 DROCON Ninja Motor Replacement: étape 7, image 2 de 3 DROCON Ninja Motor Replacement: étape 7, image 3 de 3
    • Use a Phillips #00 screwdriver to remove the two 5mm screws connecting the motor arm to the drone's body.
    • Use your fingers to gently pull the white plastic disc out of the motor arm.
  8. DROCON Ninja Motor Replacement: étape 8, image 1 de 3 DROCON Ninja Motor Replacement: étape 8, image 2 de 3 DROCON Ninja Motor Replacement: étape 8, image 3 de 3
    • Grasp the motor arm and pull up and away from the drone's body.
  9. DROCON Ninja Motor Replacement: étape 9, image 1 de 3 DROCON Ninja Motor Replacement: étape 9, image 2 de 3 DROCON Ninja Motor Replacement: étape 9, image 3 de 3
    • Use a Phillips #00 screwdriver to remove the three 4mm screws on the plate of the motor arm.
    • Using your fingers, pull apart the top and bottom pieces of the casing.
  10. DROCON Ninja Motor Replacement: étape 10, image 1 de 3 DROCON Ninja Motor Replacement: étape 10, image 2 de 3 DROCON Ninja Motor Replacement: étape 10, image 3 de 3
    • Use the opening tool to remove the small circuit board from the motor arm.
  11. DROCON Ninja Motor Replacement: étape 11, image 1 de 3 DROCON Ninja Motor Replacement: étape 11, image 2 de 3 DROCON Ninja Motor Replacement: étape 11, image 3 de 3
    • Use a pair of pliers to remove the motor by pulling up and away from the propeller arm.
2 autres ont terminé cette réparation.
1 commentaire de tutoriel
I’ve got the motor out. Thank you! Now to find a suitable replacement. Do you know the specs of the motor or a source for a working one?
Tinkerer - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 10
Total : 865
