Dell Inspiron 11-3162 Palmrest Keyboard Replacement
Introduction
Passez à l'étape 1You'd want to follow this guide if you've attempted to troubleshoot your device following our steps. The Palmrest unit is a combined keyboard and touchpad, which makes it easy for us to replace!
Ce dont vous avez besoin
Outil utilisé dans cette étape :Tweezers$4.99
Use tweezers to pry and remove the center screw cover on the back cover.
Use a Phillips screwdriver to unscrew the three 4 mm screws securing the battery.
Use the phillips screwdriver with the PH000 head to unscrew the 3.8mm screw.
Use the tweezers to unplug the DC Jack.
Gently grip and pull the speaker to remove it.
Now you've removed the Palmrest keyboard!
2 autres ont terminé cette réparation.
