Dell Inspiron 11-3180 Touchpad Replacement
Introduction
Passez à l'étape 1If you've tried the troubleshooting and it still isn't working, you may need to replace your touchpad.
ⓘ To remove the touchpad, you need to remove the battery, this does not mean you need a new battery unless that is another problem you have with your Chromebook.
ⓘ When removing and replacing touchpad, the touchpad listed doesn't come with the M8 cable so you will need to keep the cable for repair.
Ce dont vous avez besoin
Flip the Chromebook to have the bottom facing you.
Make a note of all of the screws present. You may need to uncover some of them hidden beneath plastic tabs. The location of each screw is marked in the accompanying image.
Outil utilisé dans cette étape :Tweezers$4.99
Before you completely pull off the back, you must disconnect the MB cord.
Using blunt-nosed tweezers, carefully flip the black bar that keeps the MB cord latched in as circled in the image.
Once open, grab the flat cord with your tweezers and pull horizontally until it comes free. Your bottom plate is now fully removed.
Locate the battery on the lower half of the open laptop.
Using blunt-nosed tweezers, carefully disconnect the battery cable from the service board by pulling at the small plastic tabs on either side.
Équipez-vous pour vos futures réparations
Voir tous les produits
