Aller au contenu principal
Dell Inspiron 1122 M102z Hard Drive Replacement
Terrence15
Terrence15 et 2 autres contributeurs
Dernière mise à jour le November 13, 2019
15 - 25 minutes
Modérée
Tutoriel réalisé par la communauté
In this guide, we will show you how to remove and replace the Hard Drive.
Ce dont vous avez besoin
  1. Dell Inspiron 1122 M102z Hard Drive Replacement, Remove the Screws: étape 1, image 1 de 1
    • Follow the instructions in Before You Begin.
    • Remove the two screws that secure the hard-drive assembly to the computer base.
  2. Dell Inspiron 1122 M102z Hard Drive Replacement, Disconnecting the Hard Drive: étape 2, image 1 de 1
    • Using the pull-tab, slide the hard-drive assembly to the side to disconnect it from the connector on the system board.
  3. Dell Inspiron 1122 M102z Hard Drive Replacement, Lifting the Hard-Drive Assembly: étape 3, image 1 de 1
    • Lift the hard-drive assembly out of the computer base.
  4. Dell Inspiron 1122 M102z Hard Drive Replacement, Remove the Screws: étape 4, image 1 de 1
    • Remove the four screws that secure the hard-drive bracket to the hard drive.
  5. Dell Inspiron 1122 M102z Hard Drive Replacement, Lifting the Hard-Drive Bracket: étape 5, image 1 de 1
    • Lift the hard-drive bracket off the hard drive.
  6. Dell Inspiron 1122 M102z Hard Drive Replacement, Placing the Hard Drive: étape 6, image 1 de 1
    • Place the NEW hard drive in the hard-drive bracket.
  7. Dell Inspiron 1122 M102z Hard Drive Replacement, Replace the Screws: étape 7, image 1 de 1
    • Replace the four screws that secure the hard-drive bracket to the hard drive.
  8. Dell Inspiron 1122 M102z Hard Drive Replacement, Placing the Hard-Drive Assembly: étape 8, image 1 de 1
    • Place the hard-drive assembly in the computer base.
  9. Dell Inspiron 1122 M102z Hard Drive Replacement, Sliding the Hard-Drive Assembly: étape 9, image 1 de 1
    • Using the pull-tab, slide the hard-drive assembly into the connector on the system board.
  10. Dell Inspiron 1122 M102z Hard Drive Replacement, Replace the Screws: étape 10, image 1 de 1
    • Replace the two screws that secure the hard-drive assembly to the computer base.
Terrence15
Membre depuis le 12/18/17
79 522 Réputation
441 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
43 membres
1 985 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 3
Total : 285
