Aller au contenu principal
Dell Inspiron 13 1370 Memory Modules Replacement
Terrence15
Terrence15 et un autre contributeur
Dernière mise à jour le November 13, 2019
6 - 15 minutes
Facile
Tutoriel réalisé par la communauté
In this guide, we will show you how to remove and replace Memory Modules.
Ce dont vous avez besoin
Outils
  1. Dell Inspiron 13 1370 Memory Modules Replacement, Remove the Screw: étape 1, image 1 de 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in Before You Begin.
    • Remove the screw that secures the memory module cover to the computer base.
  2. Dell Inspiron 13 1370 Memory Modules Replacement, Lifting the Memory Module Cover: étape 2, image 1 de 1
    • Use a plastic scribe to lift the memory module cover up at an angle and ease the tabs out of the computer base.
  3. Dell Inspiron 13 1370 Memory Modules Replacement, Popping up the Memory Module: étape 3, image 1 de 1
    • CAUTION: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
  4. Dell Inspiron 13 1370 Memory Modules Replacement, Removing the Memory Module: étape 4, image 1 de 2 Dell Inspiron 13 1370 Memory Modules Replacement, Removing the Memory Module: étape 4, image 2 de 2
    • Remove the memory module from the memory module connector.
  5. Dell Inspiron 13 1370 Memory Modules Replacement, Align the Notch: étape 5, image 1 de 1
    • Align the notch in the NEW memory module with the tab in the memory module connector.
  6. Dell Inspiron 13 1370 Memory Modules Replacement, Sliding the Memory Module: étape 6, image 1 de 1
    • Slide the memory module firmly into the slot at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
    • NOTE: If the memory module is not installed properly, the computer may not boot.
  7. Dell Inspiron 13 1370 Memory Modules Replacement, Align the Tabs: étape 7, image 1 de 1
    • Align the tabs on the memory module cover with the slots on the computer base and snap the cover into place.
  8. Dell Inspiron 13 1370 Memory Modules Replacement, Replace the Screw: étape 8, image 1 de 1
    • Replace the screw that secures the memory module cover to the computer base.
Terrence15
Membre depuis le 12/18/17
79 585 Réputation
441 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
43 membres
1 985 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 152
