Aller au contenu principal
Dell Inspiron 13 7378 Back Cover Replacement
Samantha Gonzalez
Samantha Gonzalez et 6 autres contributeurs
Dernière mise à jour le August 25, 2024
3 minutes
Facile
Need to access the hardware inside of your Dell Inspiron 13 7378 for a hardware fix? Or need to replace the back cover of your laptop due to physical damage? This replacement guide will guide you step by step on how to easily remove the back cover of your computer.
Ce dont vous avez besoin
Outils
  1. Dell Inspiron 13 7378 Back Cover Replacement, Back Cover: étape 1, image 1 de 1
    • Set the laptop with its underside facing up for improved accessibility.
  2. Dell Inspiron 13 7378 Back Cover Replacement: étape 2, image 1 de 2 Dell Inspiron 13 7378 Back Cover Replacement: étape 2, image 2 de 2
    • Using a Phillips #00 screwdriver, extract the nine 3 mm screws located on the back of the laptop.
  3. Dell Inspiron 13 7378 Back Cover Replacement: étape 3, image 1 de 3 Dell Inspiron 13 7378 Back Cover Replacement: étape 3, image 2 de 3 Dell Inspiron 13 7378 Back Cover Replacement: étape 3, image 3 de 3
    • Carefully pry open the back of the back of the laptop using opening picks.
    • Carefully raise and detach the back cover from the laptop.
    • Exercise caution to prevent damaging or cracking the device's back cover.
2 autres ont terminé cette réparation.
Samantha Gonzalez
Membre depuis le 02/08/22
298 Réputation
2 tutoriels rédigés
Équipe
Gateway, Team 1-3, Saknee Spring 2022 Membre de l'équipe Gateway, Team 1-3, Saknee Spring 2022
GCC-SAKNEE-S22S1G3
5 membres
16 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 14
30 derniers jours : 82
Total : 1,062
